  • Fixed issue with button animation oi Slider on SlideIN/OUT.
  • Fixed issue with with wrong image resize when Image Crop option is enabled;
  • Fixed MegaMenu responsive issue;
  • Fixed Slider shortcode issue;
  • Fixed issue with "Smooth Wheel" effect in Chrome. The smooth page scroll is not supported in Chrome v.61 and higher;
  • Added shortcode for Smooth Scrolling effect;
  • Added image Alt attribute for Image+Text control;
  • Added VK icon to Social Icons;
  • Other minor fixes and Themler stability improvements;
  • Added header.php and footer.php files;
  • Improved error messaging: added details to the error message when media upload path is invalid;
  • Fixed issue with highlighting of the Events Calendar Plugin menu items;
  • Fixed validation problems;
  • Fixed issue with "Show widget on" of the Gravity Forms plugin widgets;
  • Fixed issue with wpautop function and custom post types;
  • Fixed issue with Language control on WP 4.7+
  • Fixed ACF plugin issues;
Woocommerce
  • Fixed issue with changing product image when product variation is selected on the Product Details;
  • Fixed issue with YITH Ajax Product Filter;
  • Fixed responsive issues with Shopping Cart page;
  • Fixed issue with Add To Cart button;
  • Fixed issue with Featured Products widget;
  • Fixed issue with Shopping Cart template is there is no corresponding page defined in Woocommerce settings;
  • Fixed issue with Blog Layout columns on small screen when default Joomla blog layout is used;
  • Fixed issue with Article links;
  • Fixed issue with "Experimental" URL Routing in Joomla 3.8;
  • Fixed issue with Author URL from Themler Settings;
  • Fixed issue with missing list of templates in some cases;
  • Other minor fixes;
VirtueMart
  • Fixed issue with CartLink Localization;
  • Fixed issue with SystemPay plugin;
  • Fixed issue with VM Products modules;
  • Fixed issue with collapsing Sidebars;
  • Fixed memory linit issues related to PHP versions;
  • Fixed issue with "Image slider for your homepage" module;
HTML Themes
  • Fixed issue with Google Fonts on SSL secured websites. To fix the issue in existing projects the font should be specified again after Themler update. The fix is available for newly created links only.
### General - Fixed issue with button animation oi Slider on SlideIN/OUT. - Fixed issue with with wrong image resize when Image Crop option is enabled; - Fixed MegaMenu responsive issue; - Fixed Slider shortcode issue; - Fixed issue with "Smooth Wheel" effect in Chrome. The smooth page scroll is not supported in Chrome v.61 and higher; - Added shortcode for Smooth Scrolling effect; - Added image Alt attribute for Image+Text control; - Added VK icon to Social Icons; - Other minor fixes and Themler stability improvements; ### WordPress - Added header.php and footer.php files; - Improved error messaging: added details to the error message when media upload path is invalid; - Fixed issue with highlighting of the *Events Calendar* Plugin menu items; - Fixed validation problems; - Fixed issue with "Show widget on" of the *Gravity Forms* plugin widgets; - Fixed issue with `wpautop` function and custom post types; - Fixed issue with Language control on WP 4.7+ - Fixed *ACF* plugin issues; ### Woocommerce - Fixed issue with changing product image when product variation is selected on the Product Details; - Fixed issue with *YITH Ajax Product Filter*; - Fixed responsive issues with Shopping Cart page; - Fixed issue with Add To Cart button; - Fixed issue with Featured Products widget; - Fixed issue with Shopping Cart template is there is no corresponding page defined in Woocommerce settings; ### Joomla - Fixed issue with Blog Layout columns on small screen when default Joomla blog layout is used; - Fixed issue with Article links; - Fixed issue with "Experimental" URL Routing in Joomla 3.8; - Fixed issue with Author URL from Themler Settings; - Fixed issue with missing list of templates in some cases; - Other minor fixes; ### VirtueMart - Fixed issue with CartLink Localization; - Fixed issue with SystemPay plugin; - Fixed issue with VM Products modules; - Other minor fixes; ### Drupal - Fixed issue with collapsing Sidebars; - Fixed memory linit issues related to PHP versions; ### PrestaShop - Fixed issue with "Image slider for your homepage" module; ### HTML Themes - Fixed issue with Google Fonts on SSL secured websites. To fix the issue in existing projects the font should be specified again after Themler update. The fix is available for newly created links only.
