  • Fixed the issue with transition effect in the menu;
  • Fixed the Function create_function() is deprecated error in PHP 7.2.
WordPress and WooCommerce
  • Fixed the issue with the Show widget on option for the Products template;
  • Fixed the problem with the Use of undefined constant WC_VERSION notice;
  • Fixed the issue with highlighting of the Events Calendar plug-in menu items;
  • Added the Apply menu item tag filter option to disable HTML-tag removing from the menu items (the flag icon will now work with the WPML plug-in);
  • Fixed the layout issues with the invisible products;
  • Fixed the issue with startup of Themler with the WP Admin Theme CD plug-in;
  • Fixed the problem with the product categories display in WC 3.3;
  • Fixed the menu display issues with the UberMenu plug-in;
Joomla and VirtueMart
  • Fixed the Call to a member function get() on a non-object error for the non-authorized users;
  • Fixed the issue with the Show products of the selected category option;
  • Fixed the 404 issue when pressing the Install plug-ins button in the active theme;
PrestaShop 1.7 Beta 2
  • Added the Hook Right Column control;
  • Added the Hook control that will add the hook into your theme with the desired hook name;
  • Fixed Themler warnings when working with CartLink;
  • Fixed the issue with updating the products amount in the cart;
  • Faceted Search is now working fine;
  • Fixed the issue with switching to the Shopping Cart template;
  • Fixed the theme archivation issues for some particular php.ini configurations;
  • Some other minor fixes.
### General - Fixed the issue with transition effect in the menu; - Fixed the *Function create_function() is deprecated* error in PHP 7.2. ### WordPress and WooCommerce - Fixed the issue with the *Show widget on* option for the Products template; - Fixed the problem with the *Use of undefined constant WC_VERSION* notice; - Fixed the issue with highlighting of the *Events Calendar* plug-in menu items; - Added the *Apply menu item tag filter* option to disable HTML-tag removing from the menu items (the flag icon will now work with the WPML plug-in); - Fixed the layout issues with the invisible products; - Fixed the issue with startup of Themler with the WP Admin Theme CD plug-in; - Fixed the problem with the product categories display in WC 3.3; - Fixed the menu display issues with the UberMenu plug-in; ### Joomla and VirtueMart - Fixed the *Call to a member function get() on a non-object* error for the non-authorized users; - Fixed the issue with the *Show products of the selected category* option; - Fixed the 404 issue when pressing the Install plug-ins button in the active theme; ### PrestaShop 1.7 Beta 2 - Added the *Hook Right Column* control; - Added the *Hook* control that will add the hook into your theme with the desired hook name; - Fixed Themler warnings when working with CartLink; - Fixed the issue with updating the products amount in the cart; - Faceted Search is now working fine; - Fixed the issue with switching to the Shopping Cart template; - Fixed the theme archivation issues for some particular `php.ini` configurations; - Some other minor fixes.
