  • Added Transition Effects for Submenus, Link, Language and Currency controls.
  • Transition Effects moved to more visible place:
  • Default Styles: Improved UI for Headings:
  • Themler Desktop: added File -> Rename... option to rename themes.
  • Added Duplicate Slide option in PW for Slider control.
  • Font styles (bold/italic/underline) preview added:
  • Viewport Width/Height units are now supported:
  • Added ability to set Background, Border, Transition for typography elements, like Link Hover or Headings.
  • Added Texture Overlay effect:
  • Added Blend mode for Background.
These effects are used in popular designs and themes to make text more visible over images:
CMS
HTML
  • Fixed crash when entering the email address (with @ symbol) in the edit content area.
  • Now it's more easily to edit Page/Post properties for multiple pages (now we use non-modal panel instead of modal dialog)
  • Added Custom URL in Page Properties dialog for custom menu item url and Target property.
  • Added Date Picker for Post Date.
  • Improved Themler compatibility with WP 4.2.4 and WP 4.3.
  • FIX: Crash on adding custom template with taxonomy.php name.
  • WooCommerce: Fixed output of the Category Name and Category Image when displaying product categories.
  • FIX: Crash on starting Themler on certain hosting configurations.
  • FIX: Problem with VirtueMart slider settings on VirtueMart frontpage
  • FIX: Problem with VirtueMart categories output on VirtueMart frontpage
  • Fixed issue with enabling/disabling sidebars.
  • Solved compatibility issue with Wirecard Plugin.
  • Fixed issue with "Import from BillionThemes" for Magento themes.
  • Fixed issue with applying effects to Drupal Region controls.
What is next?
What we're working on:
  • Visual Content Editor for Joomla and Wordpress
  • New Effects and Properties
  • HTML Export for Artisteer ARTX Projects
  • Section control that allows to add ready to use sections in one click like below:
### UI - Added Transition Effects for Submenus, Link, Language and Currency controls. - Transition Effects moved to more visible place: !transition.png! - **Default Styles**: Improved UI for Headings: !ui-improvements.png! - **Themler Desktop**: added <tt>File -> Rename...</tt> option to rename themes. - Added *Duplicate Slide* option in PW for Slider control. - Font styles (bold/italic/underline) preview added: !width.png! - Viewport Width/Height units are now supported: !screenheight.png! ### Controls - Added ability to set Background, Border, Transition for typography elements, like Link Hover or Headings. - Added *Texture Overlay* effect: !texture-overlay.png! - Added *Blend mode* for Background. These effects are used in popular designs and themes to make text more visible over images: !overlay.jpg! ### CMS #### HTML - Fixed crash when entering the email address (with @ symbol) in the edit content area. - Now it's more easily to edit Page/Post properties for multiple pages (now we use non-modal panel instead of modal dialog) - Added *Custom URL* in Page Properties dialog for custom menu item url and *Target* property. - Added **Date Picker** for Post Date. #### WordPress - Improved Themler compatibility with WP 4.2.4 and WP 4.3. - FIX: Crash on adding custom template with <tt>taxonomy.php</tt> name. - **WooCommerce**: Fixed output of the Category Name and Category Image when displaying product categories. #### Joomla - FIX: Crash on starting Themler on certain hosting configurations. - FIX: Problem with **VirtueMart** slider settings on VirtueMart frontpage - FIX: Problem with **VirtueMart** categories output on VirtueMart frontpage #### Magento - Fixed issue with enabling/disabling sidebars. - Solved compatibility issue with *Wirecard* Plugin. - Fixed issue with "Import from BillionThemes" for **Magento** themes. #### Drupal - Fixed issue with applying effects to Drupal Region controls. ## What is next? What we're working on: - Visual Content Editor for Joomla and Wordpress - New Effects and Properties - HTML Export for Artisteer ARTX Projects - Section control that allows to add ready to use sections in one click like below: !section.jpg!
