The Footer widget area is a control specific for Wordpress only. Wordpress widgets can be placed into a specific widget area. Widget areas are typically positioned in webpage sidebars, however a theme can place widget areas anywhere on the page. For example, except for the usual sidebar locations, a widget area can be located in the footer of any page.
To add a Footer widget area, please navigate Insert >> Other >> Footer Widget Area.
The Footer widget area control can be placed to any location on page, however usually it is located inside the Footer control, in order to be displayed on all templates (Home, Page etc.).
There can be from one to four different Footer widget areas in a theme. You can specify whether a specific Footer widget area control will be responsible for the First, Second, Third or Fourth Area in Wordpress in Property Window >> Footer widget area >> Shape >> Options >> Footer area.
In general, the number of Footer widget areas in a theme is unlimited, as there can be several instances of a certain widget area (for example, several Third Areas) in a single theme, that will output the same widgets.
How to output widgets in Footer widget areas?
Please follow the steps below in order to output widgets in Footer widget areas of the theme:
  1. Add Footer widget area control to the theme in Themler as described below and specify its name under Footer area.
  2. Go to the Wordpress admin panel. In Appearance >> Widgets add one or several widgets to the corresponding widget area. Please note that if, for example, "Second area" is specified for the certain Footer widget area in Themler, widgets for it should be added to Second Footer Widget Area in Wordpress, but not to any other one.
  3. In Themler select File >> Refresh Content. The widgets in the Footer Widget Area willd then be displayed.
If there are no widgets in a Footer widget area, the area stays empty, and widgets can be placed into it in the Wordpress back-end at any time.
If the Footer Widget Area control is removed from the template, no widgets are output in the Footer. However, widgets still exist in the Wordpress administration area.
Footer
How to output WP Widgets in the Primary Widget Area (Video)
WordPress Widget Area
WordPress Primary Widget Area
### Summary The **Footer widget area** is a control specific for Wordpress only. Wordpress widgets can be placed into a specific widget area. Widget areas are typically positioned in webpage sidebars, however a theme can place widget areas anywhere on the page. For example, except for the usual sidebar locations, a widget area can be located in the footer of any page. ### Usage To add a **Footer widget area**, please navigate **Insert** >> **Other** >> **Footer Widget Area**. The **Footer widget area** control can be placed to any location on page, however usually it is located inside the Footer control, in order to be displayed on all templates (Home, Page etc.). There can be from one to four *different* **Footer widget areas** in a theme. You can specify whether a specific Footer widget area control will be responsible for the First, Second, Third or Fourth Area in Wordpress in **Property Window** >> **Footer widget area** >> **Shape** >> **Options** >> **Footer area**. In general, the number of **Footer widget areas** in a theme is unlimited, as there can be several instances of a certain widget area (for example, several Third Areas) in a single theme, that will output the same widgets. ### How to output widgets in Footer widget areas? Please follow the steps below in order to output widgets in Footer widget areas of the theme: 1. Add **Footer widget area** control to the theme in Themler as described below and specify its name under **Footer area**. 2. Go to the **Wordpress admin panel**. In **Appearance** >> **Widgets** add one or several widgets to the corresponding widget area. Please note that if, for example, "Second area" is specified for the certain Footer widget area in Themler, widgets for it should be added to Second Footer Widget Area in Wordpress, but not to any other one. !wp-footer-widget-area.png! 3. In Themler select **File** >> **Refresh Content**. The widgets in the Footer Widget Area willd then be displayed. If there are *no widgets* in a Footer widget area, the area stays empty, and widgets can be placed into it in the Wordpress back-end at any time. If the **Footer Widget Area** control is *removed* from the template, no widgets are output in the Footer. However, widgets still exist in the Wordpress administration area. ### Sample !footer-widget-area-control.png! ### See Also [Footer](page:4463) [How to output WP Widgets in the Primary Widget Area (Video)](page:3874) [WordPress Widget Area](page:4950) [WordPress Primary Widget Area](page:4949)
