The WordPress Primary Widget Area, as well as the WordPress Widget Area, can be used to add WordPress Widgets to your website.
Unlike the WordPress Widget Area, if the Primary Widget Area control was removed from the theme, the appropriate widget area still exists in the WordPress Appearance >> Widgets.
  1. Go to the Themler Add Control (or Insert menu) >> Other >> add WordPress Primary Widget Area control of your theme.
  2. Press Apply to CMS button.
  3. Go to WordPress > Admin > Appearance > Widgets.
  4. Add a Widget to the Primate Widget Area, e.g. Text.
  5. Return to Themler and click Refresh Content.
NOTE: Only one WP Primary Widget Area control is allowed per page.
How to output WP Widgets in the Primary Widget Area (Video)
Wordpress Footer Widget Area
### Summary The **WordPress Primary Widget Area**, as well as the [WordPress Widget Area](page:4950), can be used to add WordPress Widgets to your website. Unlike the [WordPress Widget Area](page:4950), if the Primary Widget Area control was removed from the theme, the appropriate widget area still exists in the WordPress Appearance >> Widgets. ### Usage 1. Go to the Themler **Add Control** (or **Insert** menu) >> Other >> add WordPress Primary Widget Area control of your theme. 2. Press **Apply to CMS button**. 3. Go to WordPress > Admin > Appearance > Widgets. 4. Add a **Widget** to the **Primate Widget Area**, e.g. Text. 5. Return to Themler and click Refresh Content. **NOTE**: Only one WP Primary Widget Area control is allowed per page. !wp-pwa.png! !wp-pwa2.png! ### See Also [How to output WP Widgets in the Primary Widget Area (Video)](page:3874) [WordPress Widget Area](page:4950) [Wordpress Footer Widget Area](page:4465)
