How to get your html video to parallax in the background? I use the extension but it does not work
design34
design34 posted this 24 September 2016
How to get your html video to parallax in the background? I use the extension on the section and the html box, but it does not work
see my site: http://winstead-media.com/
How to get your html video to parallax in the background? I use the extension on the section and the html box, but it does not work see my site: http://winstead-media.com/
Support Team posted this 27 September 2016
The Parallax extension works with background images only. Unfortunately it cannot be applied to video content.
Hi, The Parallax extension works with background images only. Unfortunately it cannot be applied to video content. Thank you, Olivia
Administración web
Administración web posted this 07 July 2017
Cordial saludo, quisiera saber si tienen una fecha para que Podamos tener la opcion de "Video background", "Video slide responsive" y "Video parallax scroll"
Gracias, es que en pleno auge de las tendencias web y no logro hacer esto con Themler.
Cordial saludo, quisiera saber si tienen una fecha para que Podamos tener la opcion de "Video background", "Video slide responsive" y "Video parallax scroll" Gracias, es que en pleno auge de las tendencias web y no logro hacer esto con Themler.
Support Team posted this 08 July 2017
Unfortunately those options are still not available. You can try to achieve them with some advanced solutions. Like to make the video in the background you need to put a container with the fixed position inside the template and add a video control inside. Send it back with the z-index property.
Hi, Unfortunately those options are still not available. You can try to achieve them with some advanced solutions. Like to make the video in the background you need to put a container with the fixed position inside the template and add a video control inside. Send it back with the z-index property. Sincerely, Hella
