ITSolutions Theme, SEO and Only
David Marchione
David Marchione posted this 07 October 2016
I'm looking at the ITSolutions theme on my testing server. It's pretty cool and It helps by giving me ideas for design and instruction. The Home Page template is using multiple Widgets Areas for adding content throughout the page. Is this practice something I should adopt in my designs and does it help/affect SEO?
Also my last couple designs using Themler I realized I ended up designing the whole Home page not using andy of CMS
Content Area it was all in the Template Area. Does this practice have any effect on SEO?
I'm looking at the ITSolutions theme on my testing server. It's pretty cool and It helps by giving me ideas for design and instruction. The Home Page template is using multiple Widgets Areas for adding content throughout the page. Is this practice something I should adopt in my designs and does it help/affect SEO? Also my last couple designs using Themler I realized I ended up designing the whole Home page not using andy of CMS Content Area it was all in the Template Area. Does this practice have any effect on SEO?
Support Team posted this 10 October 2016
I do not think that it will affect SEO in major way. In general the headings still use the corresponding heading tags. You can add the content using the desired headings and other elements.
Using widget areas will also make your theme more flexible.
Hi, I do not think that it will affect SEO in major way. In general the headings still use the corresponding heading tags. You can add the content using the desired headings and other elements. Using widget areas will also make your theme more flexible. Sincerely, Hella
David Marchione
David Marchione posted this 20 October 2016
Thank you.
Thank you.
Support Team posted this 21 October 2016
You are welcome. Please let us know if you have any other questions.
You are welcome. Please let us know if you have any other questions. Sincerely, Hella
