always an error
joyce92
joyce92 posted this 16 October 2016
Evey time I download from Themler.com and the opening the zip in Themler, I get an error-message saying:
The theme is missing the <code>style.css/code>stylsheet.
What to do to download the wanted theme?
Regards from the Netherlands,
Joyce
Evey time I download from Themler.com and the opening the zip in Themler, I get an error-message saying: The theme is missing the &lt;code&gt;style.css/code&gt;stylsheet. What to do to download the wanted theme? Regards from the Netherlands, Joyce
Support Team posted this 17 October 2016
Please provide a link to the Billionthemes page with the theme you have downloaded.
Hi, Please provide a link to the Billionthemes page with the theme you have downloaded. Sincerely, Hella
wbrezin2
wbrezin2 posted this 03 June 2017
This is rather aggravating. I'm a developer that has created sites from scratch and i wanted to try this product to see if it could speed up my work. I just purchased Themler. I downloaded several themes from your website. I have tried to import these Themler files (WordPress) to the Themler app. So far, nothing works!
I've received this error from several packages, even though when i unzip the file and look the missing file exists.
Templates i've tried: --
-- 2813887 http://templates.themler.com//Themes/Detail/2813887/Container-in-Full-Width-Section-art-bay
-- 2812302
http://templates.themler.com//Themes/Detail/2812302/Six-Column-Various-Width-in-the-studio
-- 2814328
http://templates.themler.com//Themes/Detail/2814328/Container-in-Full-Width-Section-art
This import stated that it could not copy an image file:
-- 2842618
http://templates.themler.com//Themes/Detail/2842618/Two-Columns-Image-Right-oil
Missing file error message:
File upload failed
Unpacking the package ...
Installing the theme ...
The package could not be installed. The theme is missing the <code>style.css</code> stylesheet.
Theme install failed.
Other message from template 2842618:
Untitled\1\assets\images\1413d72d970e745507470e711288c155_...
So what is going on here? And yes, i have updated to the latest version of Themler.
This is rather aggravating. I'm a developer that has created sites from scratch and i wanted to try this product to see if it could speed up my work. I just purchased Themler. I downloaded several themes from your website. I have tried to import these Themler files (WordPress) to the Themler app. So far, nothing works! I've received this error from several packages, even though when i unzip the file and look the missing file exists. Templates i've tried: -- -- 2813887 http://templates.themler.com//Themes/Detail/2813887/Container-in-Full-Width-Section-art-bay -- 2812302 http://templates.themler.com//Themes/Detail/2812302/Six-Column-Various-Width-in-the-studio -- 2814328 http://templates.themler.com//Themes/Detail/2814328/Container-in-Full-Width-Section-art This import stated that it could not copy an image file: -- 2842618 http://templates.themler.com//Themes/Detail/2842618/Two-Columns-Image-Right-oil Missing file error message: File upload failed Unpacking the package ... Installing the theme ... The package could not be installed. The theme is missing the &lt;code&gt;style.css&lt;/code&gt; stylesheet. Theme install failed. Other message from template 2842618: Unpacking the package ... Untitled\1\assets\images\1413d72d970e745507470e711288c155_... So what is going on here? And yes, i have updated to the latest version of Themler.
Support Team posted this 08 June 2017
The listed themes are not themes, actually. These are sections.
You can open blank Themler theme and add these sections using Section control under Insert tab >> Section >> From library.
The downloaded static html page with section cannot be imported as WordPress theme.
Hi, The listed themes are not themes, actually. These are sections. You can open blank Themler theme and add these sections using Section control under Insert tab >> Section >> From library. The downloaded static html page with section cannot be imported as WordPress theme. Thank you, Olivia
