Static Layer in Slider - Please Vote!
DaveOzric
DaveOzric posted this 19 October 2016
Hello, there are a few various sliders out there that offer a layer that is always showing on all slides that would be awesome to have in the Themler Slider.
So the option to have a button or image that remains on top of all slides.
Hello, there are a few various sliders out there that offer a layer that is always showing on all slides that would be awesome to have in the Themler Slider. So the option to have a button or image that remains on top of all slides. Thank you
10 Comments
Support Team posted this 20 October 2016
That can be done using the Themler options. Add a Container, insert the Slider into this container and add the other control that you want to be on top of the slider. For this control set the absolute position in the container and set z-index to some high value. It will be on top of the slider.
Hi, That can be done using the Themler options. Add a Container, insert the Slider into this container and add the other control that you want to be on top of the slider. For this control set the absolute position in the container and set z-index to some high value. It will be on top of the slider. Sincerely, Hella
DaveOzric
DaveOzric posted this 20 October 2016
Hello, that's interesting. I will try this. Please figure out a way to make the slider more easily responsive to contain the photo through all screen sizes asap please.
Hello, that's interesting. I will try this. Please figure out a way to make the slider more easily responsive to contain the photo through all screen sizes asap please. Thanks
It will be discussed in the separate ticket.
Hi, It will be discussed in the separate ticket. Sincerely, Hella
DaveOzric
Thank you for all your great work and support. Themler is amazing!
> Hi, > > It will be discussed in the separate ticket. > > Sincerely, > Hella Thank you for all your great work and support. Themler is amazing!
Thanks for the feedback.
Thanks for the feedback. Sincerely, Hella
DaveOzric
Keep up the great work!
DaveOzric
It does work, only downside is you can't drag the element with your mouse because it then adds it to the slide moving it from the root of the container. Not really a huge deal but might be something to consider someday.
Otherwise thanks for the tip!
It does work, only downside is you can't drag the element with your mouse because it then adds it to the slide moving it from the root of the container. Not really a huge deal but might be something to consider someday. Otherwise thanks for the tip!
Support Team posted this 21 October 2016
You are welcome. You can use outline in the left panel to drag the elements from slide to the container if positioned falsly.
You are welcome. You can use outline in the left panel to drag the elements from slide to the container if positioned falsly. Sincerely, Hella
DaveOzric
DaveOzric posted this 12 January 2018
Can we revisit this again. I am starting to use your program more for sliders now. I have a site that I want the same text and buttons on all 4 slides. Duplicating the slides is not the best practice I feel. It creates 4 sets of the same text and links.
Can you look at this and tell me if you know a way to do this? I cannot get it to.
Can we revisit this again. I am starting to use your program more for sliders now. I have a site that I want the same text and buttons on all 4 slides. Duplicating the slides is not the best practice I feel. It creates 4 sets of the same text and links. Can you look at this and tell me if you know a way to do this? I cannot get it to. Thanks
Support Team posted this 12 January 2018
There is no such direct option in the slider, but you can use my solution from the above:
Hi, There is no such direct option in the slider, but you can use my solution from the above: >That can be done using the Themler options. Add a Container, insert the Slider into this container and add the other control that you want to be on top of the slider. For this control set the absolute position in the container and set z-index to some high value. It will be on top of the slider. Sincerely, Hella
