How to use the homepage style?
shaulhadar
shaulhadar posted this 19 October 2016
Hello Themler Team.
I am trying to use the homepage style option...
I turn it on on the homepage, and than i go to the page template, and turn it off... than i change the template, but it also changes it in the homepage...
So i was wandering if you can perhaps let me know what is the correct way to use this great new feature?
Thanks for your time,
Shaul.
Hello Themler Team. I am trying to use the homepage style option... I turn it on on the homepage, and than i go to the page template, and turn it off... than i change the template, but it also changes it in the homepage... So i was wandering if you can perhaps let me know what is the correct way to use this great new feature? Thanks for your time, Shaul.
9 Comments
Support Team posted this 19 October 2016
Homepage Style allows to override fill, border and text properties for Home template (e.g. to make navbar transparent on Home page only) . It will be applied to single inner section or header Area itself. It is available on Home template only and will be applied to this template only.
So it is not needed, to disable these settings for other templates - they will stay unchanged for all templates except for the Home template.
Hello, Homepage Style allows to override fill, border and text properties for Home template (e.g. to make navbar transparent on Home page only) . It will be applied to single inner section or header Area itself. It is available on Home template only and will be applied to this template only. So it is not needed, to disable these settings for other templates - they will stay unchanged for all templates except for the Home template. Sincerely, Nettie, BillionDigital Team
DaveOzric
DaveOzric posted this 02 August 2017
Hello, I cannot seem to figure this out. Can you show me exactly how to make the homepage header transparent but the other pages a color?
Hello, I cannot seem to figure this out. Can you show me exactly how to make the homepage header transparent but the other pages a color? Thank you !2017-08-02-113741.jpg! !2017-08-02-113754.jpg!
shaulhadar
shaulhadar posted this 02 August 2017
Hi Dave, in the homepage style, there's an arrow, press it and than you can style the header only on the homepage...
After that you can go to the page template and style the header there, and this Will be the regular style...
Just a sure that homeage style is on.
Hi Dave, in the homepage style, there's an arrow, press it and than you can style the header only on the homepage... After that you can go to the page template and style the header there, and this Will be the regular style... Just a sure that homeage style is on.
DaveOzric
DaveOzric posted this 03 August 2017
I'll give it a try and let you know. Maybe I did it backwards.
DaveOzric
Not working for me.
Not working for me.
DaveOzric
No matter what I try the homepage header is not transparent.
Support Team posted this 03 August 2017
Hello Dave,
Please also make sure to set transparent or no background for the Section and Container inside Header, this can help.
Hello Dave, Please also make sure to set transparent or no background for the Section and Container inside Header, this can help. Sincerely, Nettie, BillionDigital Team
DaveOzric
DaveOzric posted this 04 August 2017
Nothing works for me. I'll have to open a new case.
Support Team posted this 04 August 2017
Hello Dave,
Ok, please open a private topic and provide temporary access to your website or attach your theme.
Hello Dave, Ok, please open a private topic and provide temporary access to your website or attach your theme. Sincerely, Nettie, BillionDigital Team
