I want to add content with green frame, can't find it.
dragana
dragana posted this 24 October 2016
Where can I find Posts >> Add Control?
Support Team posted this 25 October 2016
Make sure that the CMS Content is enabled under the Insert >> Content and Sidebars.
Hela
Hi, Make sure that the CMS Content is enabled under the Insert >> Content and Sidebars. Sincerely, Hela
info2934
info2934 posted this 05 July 2019
hi, i have the same problem. I tried to enable the descripted item but i'm still not able to add it. What could i do?
Support Team posted this 05 July 2019
Please make sure there is some page or post assigned to this menu item. Then try to disable and enable CMS content. Also you may need to click Refresh Content after this.
Hello, Please make sure there is some page or post assigned to this menu item. Then try to disable and enable CMS content. Also you may need to click Refresh Content after this. Sincerely, Nettie
