Problem with Horizontal Menu Submenu in Joomla 3.6.3
JEMmarketing
JEMmarketing posted this 27 October 2016
I have created a simple horizontal menu in my template header.
I am having 2 problems at this time. The first is that the submenu disappears when I move the cursor past the first submenu item, making it impossible to click on the items below the first item.
The second problem is that the submenu shows up behind other sections on pages, such as behind the slider on the homepage, and behind the content on other pages.
How do I adjust the settings so that the submenu stays visible on top of all content and is clickable past the first submenu item?
I cannot provide a link because the site is not yet live, but I have attached a zip file of the template. Please advise.
I have created a simple horizontal menu in my template header. I am having 2 problems at this time. The first is that the submenu disappears when I move the cursor past the first submenu item, making it impossible to click on the items below the first item. The second problem is that the submenu shows up behind other sections on pages, such as behind the slider on the homepage, and behind the content on other pages. How do I adjust the settings so that the submenu stays visible on top of all content and is clickable past the first submenu item? I cannot provide a link because the site is not yet live, but I have attached a zip file of the template. Please advise.
10 Comments
Support Team posted this 28 October 2016
Try to set the high z-index value for the Header, it works fine on my side, but may be working different on your site with your content.
Hi, Try to set the high z-index value for the Header, it works fine on my side, but may be working different on your site with your content. Sincerely, Hella
JEMmarketing
JEMmarketing posted this 28 October 2016
What should it be set to?
Support Team posted this 30 October 2016
Please see the attached screenshot:
This should help.
Hi, Please see the attached screenshot: !header-z-index-2.png! This should help. Thank you, Olivia
Seagull
Seagull posted this 13 May 2017
I'm having the same problem. I've never had this happen with Themler before, is it a bug that has been introduced?
I have followed the instructions, apart from two differences:
  • My header has 3 sections, the first contains a topbar with a menu and social links, the second is empty (will explain further down) and the third had a logo, textbox with phone number, searchbox and a hamburger type menu at the end.
  • Instead of setting the entire header z-index 100 I had to set the topbar section z-index 100 as the logo in the section below kept appearing over the top of the submenu even if I set the z-index to -1 and position to relative on all of them. Setting it to -1 also had the unfortunate side effect of making the logo disappear under the section.
  • After setting the topbar to relative and 100 z-index then I realised that the entire page content below the header was also covering the submenu items. This was on every template. Selecting content and sidebars and setting them to relative position and -1 z-ndex fixed this but I had to do it on every template grr
  • However Just when I thought I'd got it all sorted then I realised that even though the submenu was now appearing on top of everything that if you try to hover over it it disappears!
I'm tearing my hair out now with this...
  • as mentioned above the reason that I have an empty section sandwiched between the other two is that if I remove it all the containers in the layout of the section below messes up, jumbled everywhere. I have no idea why. I've inspected both sections, the middle one is completely empty and the only setting on it is height to auto.
Any insights on this please? I'm tearing my hair out here.
Best regards,
Angela
Hello, I'm having the same problem. I've never had this happen with Themler before, is it a bug that has been introduced? I have followed the instructions, apart from two differences: - My header has 3 sections, the first contains a topbar with a menu and social links, the second is empty (will explain further down) and the third had a logo, textbox with phone number, searchbox and a hamburger type menu at the end. - Instead of setting the entire header z-index 100 I had to set the topbar section z-index 100 as the logo in the section below kept appearing over the top of the submenu even if I set the z-index to -1 and position to relative on all of them. Setting it to -1 also had the unfortunate side effect of making the logo disappear under the section. - After setting the topbar to relative and 100 z-index then I realised that the entire page content below the header was also covering the submenu items. This was on every template. Selecting content and sidebars and setting them to relative position and -1 z-ndex fixed this but I had to do it on every template grr - **However Just when I thought I'd got it all sorted then I realised that even though the submenu was now appearing on top of everything that if you try to hover over it it disappears!** I'm tearing my hair out now with this... * as mentioned above the reason that I have an empty section sandwiched between the other two is that if I remove it all the containers in the layout of the section below messes up, jumbled everywhere. I have no idea why. I've inspected both sections, the middle one is completely empty and the only setting on it is height to auto. Any insights on this please? I'm tearing my hair out here. Best regards, Angela
l.fleisch
l.fleisch posted this 10 July 2017
I'm having the same problem. I have followed this thread and tried to apply all suggestions without any success. Please see the attached screen shot. The submenu disappears after the first Item hover.
So in other words when I go to hover over the second item the whole submenu disappears.
I tried to change the Z-index as specified in the other posts without any resulting changes.
Please advise how to fix this.
I'm having the same problem. I have followed this thread and tried to apply all suggestions without any success. Please see the attached screen shot. The submenu disappears after the first Item hover. So in other words when I go to hover over the second item the whole submenu disappears. I tried to change the Z-index as specified in the other posts without any resulting changes. Please advise how to fix this.
Support Team posted this 12 July 2017
l.fleisch,
We already answered you in your private topic.
l.fleisch, We already answered you in your private topic. Thank you, Olivia
jcamino
jcamino posted this 28 July 2017
Hi, I´m having exactly the same problem and the "z-index" suggestion didn´t work for me. As a review of the problem:
"The submenu disappears when I move the cursor past the first submenu item, making it impossible to click on the items below the first item. The second problem is that the submenu shows up behind other sections on pages, such as behind the slider on the homepage, and behind the content on other pages" (JEMmarketing).
It´s urgent for me to solve this issue. Thanks.
PD:. By the way, I have this problem in Wordpress too.
Hi, I´m having exactly the same problem and the "z-index" suggestion didn´t work for me. As a review of the problem: "The submenu disappears when I move the cursor past the first submenu item, making it impossible to click on the items below the first item. The second problem is that the submenu shows up behind other sections on pages, such as behind the slider on the homepage, and behind the content on other pages" (JEMmarketing). It´s urgent for me to solve this issue. Thanks. PD:. By the way, I have this problem in Wordpress too.
Support Team posted this 29 July 2017
Usually the problem is solved by setting the position option for the Header control to relative and z-index to 1000. If that does not help, create a private post with the access to the site back end.
Hi, Usually the problem is solved by setting the position option for the Header control to `relative` and z-index to `1000`. If that does not help, create a private post with the access to the site back end. Sincerely, Hella
jcamino
jcamino posted this 29 July 2017
Yes, that solved my problem. Thanks you very much for your support.
Support Team posted this 30 July 2017
You're welcome!
Please let us know if you need our further assistance.
Themler Team
Hi, You're welcome! Please let us know if you need our further assistance. Thank you, Themler Team
