Shortcode and CSS
oceanite
oceanite posted this 29 October 2016
How to apply different css for each shortcode ?
When I put a css to a shortcode, all shortcodes use this css. This code is also used by widgets. It is a problem this behavior
I use woocommerce.
Hello, How to apply different css for each shortcode ? When I put a css to a shortcode, all shortcodes use this css. This code is also used by widgets. It is a problem this behavior I use woocommerce. Thanks
Support Team posted this 01 November 2016
What exactly shortcodes you're referring to (Themler or woocommerce shortcodes)?
What exactly css you want to add to the shortcode?
Hi, What exactly shortcodes you're referring to (Themler or woocommerce shortcodes)? What exactly css you want to add to the shortcode? Thank you, Olivia
oceanite
oceanite posted this 01 November 2016
Within themler: insert > more > shortcode.
Later, I write : [product_page id="1125"] and modify CSS
Hello, Within themler: insert > more > shortcode. Later, I write : [product_page id="1125"] and modify CSS Thanks
Support Team posted this 07 November 2016
Hello Jesus,
as you're using the Themler shortcode control you may change settings specific for this control:
You may also add custom CSS under "CSS" option.
If it's not enough and you cannot implement something specific please provide direct link to your page and let us know what you'd like to do.
Hello Jesus, as you're using the Themler shortcode control you may change settings specific for this control: !ControlStyle.png! You may also add custom CSS under "CSS" option. If it's not enough and you cannot implement something specific please provide direct link to your page and let us know what you'd like to do. regards, Aileen
oceanite
oceanite posted this 07 November 2016
css, not style.
css: in that place the code is used by others shortcodes
thaks
css, not style. css: in that place the code is used by others shortcodes thaks
Support Team posted this 08 November 2016
In this case you need to find the specific class names that are used in this shortcode content to address the CSS styles to this shortcode only.
Hi, In this case you need to find the specific class names that are used in this shortcode content to address the CSS styles to this shortcode only. Sincerely, Hella
oceanite
oceanite posted this 08 November 2016
Ok,
Ok, Thanks Regards
Support Team posted this 09 November 2016
Let us know if you need our further help.
Let us know if you need our further help. Sincerely, Hella
