Form - only in one page
raffe
raffe posted this 31 October 2016
I have a question,
How can I add the "Form" only one page?
If I add "Form" is automatically added also to the other pages in the website...
and can I add "Form" to the column?
Hello, I have a question, How can I add the "Form" only one page? If I add "Form" is automatically added also to the other pages in the website... and can I add "Form" to the column?
Support Team posted this 01 November 2016
To make some control appear only on one page, you need to add it inside the green content area.
You can also add it in the sidebar, but that will appear on all pages that uses that sidebar. You can consider using the Joomla plug-in to create a form and insert that module in the desired page only.
Hi, To make some control appear only on one page, you need to add it inside the green content area. You can also add it in the sidebar, but that will appear on all pages that uses that sidebar. You can consider using the Joomla plug-in to create a form and insert that module in the desired page only. Sincerely, Hella
mz.musical
mz.musical posted this 26 January 2017
hi
raffe said right, when we select the form and drag it to green content, the green line doesn't appear in the cms content to do the dropping job. and in that time , we can see just the other colors expect green.
and that form can't drag to column or layout container
it's right that we can use other plugins for making forms and put their shortcodes in other places "but" we want use just themler form
this problem detected in themler and it may have a solution.
notice : i think the best feedback coming from the user of each software, but each time i send a note to support team for resolving problem i couldn't got the Appropriate response, and they thought that we couldn't use themler properly while that problems is from themler software.
this software have many good properties but it have problems so like drag and drop problem that many times can't be done or don't handled correctly or handled so difficult.
hi raffe said right, when we select the form and drag it to green content, the green line doesn't appear in the cms content to do the dropping job. and in that time , we can see just the other colors expect green. and that form can't drag to column or layout container it's right that we can use other plugins for making forms and put their shortcodes in other places "but" *we want use just themler form* this problem detected in themler and it may have a solution. notice : i think the best feedback coming from the user of each software, but each time i send a note to support team for resolving problem i couldn't got the Appropriate response, and they thought that we couldn't use themler properly while that problems is from themler software. this software have many good properties but it have problems so like drag and drop problem that many times can't be done or don't handled correctly or handled so difficult.
Support Team posted this 30 January 2017
The Form control as well as some other controls cannot be added to the green CMS content area and converted to the content shortcodes. So, the reported issue is behaviour by default.
Please note that Themler Form does not provide server action code. Therefore the single form will not work. If you're working with CMS the third-party plugins are better and easy-to-use than Themler Form.
Hi, The Form control as well as some other controls cannot be added to the green CMS content area and converted to the content shortcodes. So, the reported issue is behaviour by default. Please note that Themler Form does not provide server action code. Therefore the single form will not work. If you're working with CMS the third-party plugins are better and easy-to-use than Themler Form. Thank you, Olivia
mgauto
mgauto posted this 19 June 2017
I've had the same problem thus I arrived here. Any pointers at least to a third-party plug in that will let me insert a simple Contact form into only one page? Total new guy to all this here, so please aid me a little bit.
Thank you very much.
Hello, I've had the same problem thus I arrived here. Any pointers at least to a third-party plug in that will let me insert a simple Contact form into only one page? Total new guy to all this here, so please aid me a little bit. Thank you very much.
Support Team posted this 19 June 2017
You can find a lot of different contact forms for Joomla here:
https://extensions.joomla.org/category/contacts-and-feedback/contact-forms/
If you need them for any other CMS, just google the contact forms for your CMS and you'll see numerous plug-ins for various taste.
Hi, You can find a lot of different contact forms for Joomla here: https://extensions.joomla.org/category/contacts-and-feedback/contact-forms/ If you need them for any other CMS, just google the contact forms for your CMS and you'll see numerous plug-ins for various taste. Sincerely, Hella
