Prestashop article page image mouseover effect
Maniko
Maniko posted this 03 November 2016
I am using themler with prestashop and can´t find any solution to disable this creepy mouseover effect on the product image on the article detail page. we just need a simple effect with bigger image after clicking. with this strange mouseover effect thats implemented, the image appears on the right side and covers the important texts.
thanks for helping us out and best regards,
manfred
Hello, I am using themler with prestashop and can´t find any solution to disable this creepy mouseover effect on the product image on the article detail page. we just need a simple effect with bigger image after clicking. with this strange mouseover effect thats implemented, the image appears on the right side and covers the important texts. thanks for helping us out and best regards, manfred
Support Team posted this 07 November 2016
I assume that you're referring to the CloudZoom effect on the Product Details template, right?
Unfortunately this cannot be disabled. Themler product Image supports only one effect,
Hi, I assume that you're referring to the CloudZoom effect on the Product Details template, right? Unfortunately this cannot be disabled. Themler product Image supports only one effect, Thank you, Olivia
Maniko
Maniko posted this 07 November 2016
yes, that´s what I meant. Is there a possibilty to just disable coudzoom generally? That means: image without any effect.
manfred
Hello, yes, that´s what I meant. Is there a possibilty to just disable coudzoom generally? That means: image without any effect. Thanks, manfred
Support Team posted this 10 November 2016
Unfortunately this effect is a part of the control and cannot be disabled.
If you know how to output the product image by code you can use CMS Code control (Insert tab >> More).
The one more alternative is to remove(or rename) CloudZoom.js from the theme project.
But you will get errors in console in this case (script not found, etc).
Hi, Unfortunately this effect is a part of the control and cannot be disabled. If you know how to output the product image by code you can use **CMS Code** control (Insert tab >> More). The one more alternative is to remove(or rename) CloudZoom.js from the theme project. But you will get errors in console in this case (script not found, etc). Thank you, Olivia
WALLOON
WALLOON posted this 16 June 2017
In the template directory - there is a CloudZoom.js file :
Edit this line
$mouseTrap.bind('mouseenter', this, function (event) {
and change to
$mouseTrap.bind('mouseenterxxxx', this, function (event) {
You must change the file each time your regenerate the theme.
It working for us :)
Remy
In the template directory - there is a CloudZoom.js file : Edit this line $mouseTrap.bind('mouseenter', this, function (event) { and change to $mouseTrap.bind('mouseenterxxxx', this, function (event) { You must change the file each time your regenerate the theme. It working for us :) Remy
