descriptive submenu wordpress
Linkebel
Linkebel posted this 08 November 2016
I would like to see a description in the submenu
Is this possible via Themeler or adding php code?
Thank you.
Hello, I would like to see a description in the submenu Is this possible via Themeler or adding php code? Thank you.
10 Comments
Support Team posted this 09 November 2016
Please provide a screen shot explaining what you want to implement, it's not clear.
Hi, Please provide a screen shot explaining what you want to implement, it's not clear. Sincerely, Hella
Linkebel
Linkebel posted this 09 November 2016
https://postimg.org/image/z6zwlvd4t/
https://postimg.org/image/3m185q3oj/
Hi, https://postimg.org/image/z6zwlvd4t/ https://postimg.org/image/3m185q3oj/ Thank you
Linkebel
Linkebel posted this 10 November 2016
Up please
Up please
Linkebel
Linkebel posted this 11 November 2016
So news?
Hello, So news?
Linkebel
Linkebel posted this 14 November 2016
Would it be possible to have an answer?
Unfortunately your forum is not reactive at all, we have deadlines vis-à-vis our customers and your response time is way too big, which is decriminalizing us. This is a point that makes me look elsewhere for template design.
Hello, Would it be possible to have an answer? Unfortunately your forum is not reactive at all, we have deadlines vis-à-vis our customers and your response time is way too big, which is decriminalizing us. This is a point that makes me look elsewhere for template design.
Support Team posted this 15 November 2016
I'm terribly sorry for the delay. Unfortunately there is no possibility to display the description. I'll add your suggestion to our wish list for possible future implementations.
Hi, I'm terribly sorry for the delay. Unfortunately there is no possibility to display the description. I'll add your suggestion to our wish list for possible future implementations. Sincerely, Hella
Linkebel
Linkebel posted this 15 November 2016
I found this page : http://www.wpbeginner.com/wp-themes/how-to-add-menu-descriptions-in-your-wordpress-themes/
Could it work?
Hi, I found this page : http://www.wpbeginner.com/wp-themes/how-to-add-menu-descriptions-in-your-wordpress-themes/ Could it work?
Support Team posted this 17 November 2016
we haven't tested this solution with Themler themes. But I afraid that it won't work because Menu used in Themler themes is not standard WP menu.
However you may try the solution by yourself and check.
Hello, we haven't tested this solution with Themler themes. But I afraid that it won't work because Menu used in Themler themes is not standard WP menu. However you may try the solution by yourself and check. Regards, Aileen
Linkebel
Linkebel posted this 18 November 2016
I do not understand why you do not use the Wordpress menu.
It is the same with the zoom on products Woocommerce or Prestsashop.
Therefore we have a lot of trouble setting these options and must find other solutions than Themeler.
For the mega menu I will use the plugin Ubermenu, but then what use me mega menu option of Themler if I can not adapt it to my needs ??
You lose a lot of time with these "nonsense" and do not develop what we need (like the visual editor)
You have to create sections, good idea, but what is it for if the customer can not modify them ???
Themler sinks more and more, whereas at first I thought it was really great.
I do not understand why you do not use the Wordpress menu. It is the same with the zoom on products Woocommerce or Prestsashop. Therefore we have a lot of trouble setting these options and must find other solutions than Themeler. For the mega menu I will use the plugin Ubermenu, but then what use me mega menu option of Themler if I can not adapt it to my needs ?? You lose a lot of time with these "nonsense" and do not develop what we need (like the visual editor) You have to create sections, good idea, but what is it for if the customer can not modify them ??? Themler sinks more and more, whereas at first I thought it was really great.
Support Team posted this 21 November 2016
Hello Nicolas,
Themler themes are not using standard WP menu to be able to add specific options (all you see in Horizontal Menu) for it.
We're aware that some plugins are not working with Themler menu.
Please let us know if you have additional questions.
Hello Nicolas, Themler themes are not using standard WP menu to be able to add specific options (all you see in Horizontal Menu) for it. We're aware that some plugins are not working with Themler menu. Please let us know if you have additional questions. regards, Aileen
