Billionthemler - social media icons in header
TSMM
TSMM posted this 22 April 2015
I am creating a wordpress theme, and would like to include a number of social media icons in the top row. I managed to get one in for Facebook but can't see how to add one for Twitter, YouTube etc
Support Team posted this 22 April 2015
Hello Tracy,
you may change the Icon image of the control to create other social icon. Here are the steps:
1. Add Icon Link control
2. open control's Options, select Image and select new icon
Change icon color if needed under Icon Options
3.change URL
You'll get a new icon
Hello Tracy, you may change the Icon image of the control to create other social icon. Here are the steps: 1. Add Icon Link control !IconStep1.png! 2. open control's Options, select Image and select new icon !IconStep2.png! Change icon color if needed under Icon Options 3.change URL !IconStep3.png! You'll get a new icon !IconResult.png! Regards, Aileen
tanya3
tanya3 posted this 14 August 2015
I'm working with Wordpress and used to be an Artisteer customer.
I'm trying to add multiple social media icons in a row quite close together. I understand how to change the icon's image (from the comments above) and add a link. However, I can't seem to get them in the same row, 10 px apart, with a right side alignment.
I'm working with Wordpress and used to be an Artisteer customer. I'm trying to add multiple social media icons in a row quite close together. I understand how to change the icon's image (from the comments above) and add a link. However, I can't seem to get them in the same row, 10 px apart, with a right side alignment.
Support Team posted this 14 August 2015
Could you please provide a link to your site so we could see the issue.
Basically you need to add a row with the desired amount of columns, stretch columns to be the desired width and set the padding for each column to achieve the desired space between the icons.
Hi, Could you please provide a link to your site so we could see the issue. Basically you need to add a row with the desired amount of columns, stretch columns to be the desired width and set the padding for each column to achieve the desired space between the icons. Sincerely, Hella BillionDigital Team
tanya3
tanya3 posted this 17 August 2015
I inserted a container added everything I wanted to the container then set padding and alignment. Worked!
Thank you.
I inserted a container added everything I wanted to the container then set padding and alignment. Worked! Thank you.
Support Team posted this 17 August 2015
You're welcome.
Just let us know if you need any further help.
Ivan
You're welcome. Just let us know if you need any further help. Thanks, Ivan
