Add CSS Class and id to containers
Denis L.
Denis L. posted this 11 November 2016
I'm working on a Themler HTML template and I would like to know if it's possible within Themler to add custom CSS class and/or ID to containers and other items like buttons, images, etc. to identify them and have more control over them design-wise? If yes, could someone please explain to me where to find the option? Looked everywhere but didn't find it.
If it's not in Themler, it would definitively be a must have all through Themler software (HTML, Joomla, etc.).
Thanks in advance for the help.
Best regards,
Denis.
Hi, I'm working on a Themler HTML template and I would like to know if it's possible within Themler to add custom CSS class and/or ID to containers and other items like buttons, images, etc. to identify them and have more control over them design-wise? If yes, could someone please explain to me where to find the option? Looked everywhere but didn't find it. If it's not in Themler, it would definitively be a must have all through Themler software (HTML, Joomla, etc.). Thanks in advance for the help. Best regards, Denis.
10 Comments
Support Team posted this 14 November 2016
Now it is possible for the Section only. But actually each element has the unique class name already. To see it, use the inspect element feature in your browser. Then you can add that CSS code under the Home >> Settings >> Additional CSS.
Hi, Now it is possible for the Section only. But actually each element has the unique class name already. To see it, use the inspect element feature in your browser. Then you can add that CSS code under the Home >> Settings >> Additional CSS. Sincerely, Hella
Denis L.
Denis L. posted this 15 November 2016
Ok thanks Hella. Will do that.
And might I suggest that it would be a great addition to themler to add a "Custom CSS class" field option for each controls and elements (containers, columns, buttons, etc.). ;-)
Ok thanks Hella. Will do that. And might I suggest that it would be a great addition to themler to add a "Custom CSS class" field option for each controls and elements (containers, columns, buttons, etc.). ;-)
Support Team posted this 16 November 2016
We already have this suggestion in our wish list. We'll add your vote to it.
Themler Team
Hi, We already have this suggestion in our wish list. We'll add your vote to it. Thank you, Themler Team
Paul T
Paul T posted this 02 February 2017
Also to be able to add a Title attribute to an image
shaulhadar
shaulhadar posted this 02 February 2017
Hi Paul , you already have the image alt title option....just press on an image and look at the top bar, you will see a place for a link , and under it a place for an alt tag.
Paul T
Paul T posted this 04 February 2017
Thanks shaulhadar, I saw that but alt tags and title tags aren't the same thing. Title tags can be used in some extensions to add captions to images.
Kenny k
Kenny k posted this 08 August 2017
Themler Team
And add my vote to it as well.
> Hi, > > We already have this suggestion in our wish list. We'll add your vote to it. > > Thank you, > Themler Team And add my vote to it as well.
Web IT Solutions LLP
Web IT Solutions LLP posted this 16 October 2017
Best regards,
Denis.
We too need this valuable feature in Themler...
Suffian Ahmed
> Hi, > > I'm working on a Themler HTML template and I would like to know if it's possible within Themler to add custom CSS class and/or ID to containers and other items like buttons, images, etc. to identify them and have more control over them design-wise? If yes, could someone please explain to me where to find the option? Looked everywhere but didn't find it. > > If it's not in Themler, it would definitively be a must have all through Themler software (HTML, Joomla, etc.). > > Thanks in advance for the help. > > Best regards, > Denis. We too need this valuable feature in Themler... Regards Suffian Ahmed
hdm
hdm posted this 20 March 2018
Hello. I'm also waiting for this update.
In the meantime I tried to add class "alas-rullaus" in to "header":
$(function(){
$('#header').addClass('alas-rullaus');
This does not seem to work?
Can anyone help? Thanks.
Hello. I'm also waiting for this update. In the meantime I tried to add class "alas-rullaus" in to "header": $(function(){ $('#header').addClass('alas-rullaus'); }); This does not seem to work? Can anyone help? Thanks.
Support Team posted this 22 March 2018
If you created proper js then it should work. But please note that you're using identifier based on ID: #header. It is looking for element with id="header". Please make sure that you have the element with this ID. If the code is not working please check the browser Console for more details.
Hi, If you created proper js then it should work. But please note that you're using identifier based on ID: `#header`. It is looking for element with `id="header"`. Please make sure that you have the element with this ID. If the code is not working please check the browser Console for more details. Thank you, Olivia
