Remove leaking raw shortcodes from Themler excerpts
Stagger Lee posted this 23 April 2015
Theme functions.php or functions.php inside a plugin:
function remove_shortcode_from_excerpt($content) {
$content = strip_shortcodes( $content );
return $content;//always return $content
add_filter('the_excerpt', 'remove_shortcode_from_excerpt');
add_filter('get_the_excerpt', 'remove_shortcode_from_excerpt');
It sholud be inside Themler code at default. Excerpts are leaking many raw shortcodes. Specially caption shortcode from inserted images.
Theme functions.php or functions.php inside a plugin: function remove_shortcode_from_excerpt($content) { $content = strip_shortcodes( $content ); return $content;//always return $content } add_filter('the_excerpt', 'remove_shortcode_from_excerpt'); add_filter('get_the_excerpt', 'remove_shortcode_from_excerpt'); It sholud be inside Themler code at default. Excerpts are leaking many raw shortcodes. Specially caption shortcode from inserted images.
Support Team posted this 23 April 2015
Hello Stager Lee,
thank you for your suggestion, I passed it to our engineers for review and it will be considered as possible improvement.
Hello Stager Lee, thank you for your suggestion, I passed it to our engineers for review and it will be considered as possible improvement. regards, Aileen
Support Team posted this 08 May 2015
Done.
The improvement will be available in the next update.
Hello Done. The improvement will be available in the next update. Thank you, Olivia
Stagger Lee posted this 14 January 2016
You probably changed something in code latest so shortcodes are again visible in excerpts.
Stagger Lee posted this 15 January 2016
theme_get_excerpt doesnt work in same way as WP native the_excerpt.
So statement in topic under is not true.
https://answers.themler.com/questions/30292/other-plugin-shortcode
theme_get_excerpt doesnt work in same way as WP native the_excerpt. So statement in topic under is not true. https://answers.themler.com/questions/30292/other-plugin-shortcode
Stagger Lee posted this 17 January 2016
On one theme I get this in excerpts. If WP gallery is fiirst in Post.
#gallery-1 { margin: auto; } #gallery-1 .gallery-item { float: left; margin-top: 10px; text-align: center; width: 33%; } #gallery-1 img { border: 2px solid #cfcfcf; } #gallery-1 .gallery-caption { margin-left: 0; } /* see gallery_shortcode() in wp-includes/media.php */ Share on Facebook
On one theme I get this in excerpts. If WP gallery is fiirst in Post. #gallery-1 { margin: auto; } #gallery-1 .gallery-item { float: left; margin-top: 10px; text-align: center; width: 33%; } #gallery-1 img { border: 2px solid #cfcfcf; } #gallery-1 .gallery-caption { margin-left: 0; } /* see gallery_shortcode() in wp-includes/media.php */ Share on Facebook
Native WP "the_excerpt" remove shortodes from excerpts. Please fix it, this is not so small problem.
Support Team posted this 21 January 2016
Hello Stagger Lee,
I'm passing it to developers for review.
We'll contact you when we receive a response.
Hello Stagger Lee, I'm passing it to developers for review. We'll contact you when we receive a response. regards, Aileen
