Upset! Get cpgz extension when I unzip my theme.
FloridaMMA
FloridaMMA posted this 13 November 2016
I desgned a beautiful website with themler , I export it, Zip file is created. When i unzip the file I get another zip file with the extension CPGZ. CPGZ files are created when I double-click a .ZIP file in Mac OS X. Upon opening the ZIP file, a new file with the same name but the ".cpgz" extension is created. Then, when I decompress the CPGZ file, it gives you back a copy of the original ZIP file. This loop is caused because ZIP file is corrupt. How do I fix this problem. I just bought the program today! I don't want to ask for my money back. Please help.
Support Team posted this 14 November 2016
Please could you try one of the following suggestions:
http://osxdaily.com/2013/02/13/open-zip-cpgz-file/
Hi, Please could you try one of the following suggestions: http://osxdaily.com/2013/02/13/open-zip-cpgz-file/ Sincerely, Hella
FloridaMMA
FloridaMMA posted this 14 November 2016
i tried all examples. Here is what I get when I use the solution using the terminal. Instead of it opening the file I get this error message:
Last login: Sun Nov 13 16:47:24 on ttys000
Juans-Mac-mini:~ juanmorejon$ unzip /Users/juanmorejon/Desktop/feria1.zip.cpgz
Archive: /Users/juanmorejon/Desktop/feria1.zip.cpgz
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
unzip: cannot find zipfile directory in one of /Users/juanmorejon/Desktop/feria1.zip.cpgz or
/Users/juanmorejon/Desktop/feria1.zip.cpgz.zip, and cannot find /Users/juanmorejon/Desktop/feria1.zip.cpgz.ZIP, period.
please help I have a client who is upset..was due this morning! I have been on this since yesterday!!!
Can I send you the zip file and see if you can open it?
i tried all examples. Here is what I get when I use the solution using the terminal. Instead of it opening the file I get this error message: Last login: Sun Nov 13 16:47:24 on ttys000 Juans-Mac-mini:~ juanmorejon$ unzip /Users/juanmorejon/Desktop/feria1.zip.cpgz Archive: /Users/juanmorejon/Desktop/feria1.zip.cpgz End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive. In the latter case the central directory and zipfile comment will be found on the last disk(s) of this archive. unzip: cannot find zipfile directory in one of /Users/juanmorejon/Desktop/feria1.zip.cpgz or /Users/juanmorejon/Desktop/feria1.zip.cpgz.zip, and cannot find /Users/juanmorejon/Desktop/feria1.zip.cpgz.ZIP, period. Juans-Mac-mini:~ juanmorejon$ please help I have a client who is upset..was due this morning! I have been on this since yesterday!!! Can I send you the zip file and see if you can open it?
Support Team posted this 18 November 2016
Could you please attach the problem archive?
Also please try exporting theme into a different directory (on the Desktop, for example) and from the browser using the following address:
http://127.0.0.1:29958/themler_2316630085/joomla/administrator
The theme itself is located under the Applications >> Themler (open package) >> Contents >> Resources >> hd_data >> themler_[numbers] >> joomla >> templates.
Hi, Could you please attach the problem archive? Also please try exporting theme into a different directory (on the Desktop, for example) and from the browser using the following address: `http://127.0.0.1:29958/themler_2316630085/joomla/administrator` The theme itself is located under the Applications >> Themler (open package) >> Contents >> Resources >> hd_data >> themler_[numbers] >> joomla >> templates. Please keep us posted about the progress. Thank you, Olivia
