How can I use ZIP template?
videokommando
videokommando posted this 07 August 2014
Hi!
I bought a Subscription with 75% discount.
I downloaded 10 Themes, but i found not the .artx files.
How can I import this themes to Artisteer?
Thank you.
Janos Szucs
Hi! I bought a Subscription with 75% discount. I downloaded 10 Themes, but i found not the .artx files. How can I import this themes to Artisteer? Thank you. Janos Szucs
jrgweb
jrgweb posted this 08 August 2014
Hey Janos,
Not sure I understand the problem. If you are signed in you will get a download button. Simply download. If you are not signed in you will get a Buy button for $2.99.
I just tested this and the download is the artx. I already have 453 of the artx. They claim 600 + but there are many that are duplicated.
jrgweb
Hey Janos, Not sure I understand the problem. If you are signed in you will get a download button. Simply download. If you are not signed in you will get a Buy button for $2.99. I just tested this and the download is the artx. I already have 453 of the artx. They claim 600 + but there are many that are duplicated. jrgweb
Support Team posted this 08 August 2014
Janos, if the themes you downloaded are in ZIP format, then simply rename them to ARTX, e.g. test.zip -> test.artx
Alternatively use Google Chrome and FF browsers which do not convert ARTX files by downloading so you should see ARTX files on your computer.
James, we will check the themes in order to remove duplicates. Thanks for posting this.
Janos, if the themes you downloaded are in ZIP format, then simply rename them to ARTX, e.g. test.zip -> test.artx Alternatively use Google Chrome and FF browsers which do not convert ARTX files by downloading so you should see ARTX files on your computer. James, we will check the themes in order to remove duplicates. Thanks for posting this.
videokommando
videokommando posted this 08 August 2014
Thank you. The renaming helped. :)
Support Team posted this 11 August 2014
You're welcome!
You're welcome!
