Themler Not Working With Wordpress
arran_sheppard
arran_sheppard posted this 29 November 2016
How do I solve this when trying to edit a theme inside Wordpress?
Error
How do I solve this when trying to edit a theme inside Wordpress? ![Error][1] [1]: https://s17.postimg.org/ifze997lr/error.png
Support Team posted this 30 November 2016
Hello Arran,
I'm sorry but the issue is not quite clear. Please provide the exact steps you follow
Hello Arran, I'm sorry but the issue is not quite clear. Please provide the exact steps you follow regards, Aileen
arran_sheppard
arran_sheppard posted this 03 December 2016
So I go to edit the theme inside Wordpress by clicking this"
Edit theme
Then I get this error:
Error
I have the Themler Core installed, but not having any luck.
I never used to have this problem?
So I go to edit the theme inside Wordpress by clicking this" ![Edit theme][1] Then I get this error: ![Error][2] I have the Themler Core installed, but not having any luck. I never used to have this problem? [1]: https://s16.postimg.org/5cp0uid5h/Screen_Shot_2016_12_03_at_16_05_45.png [2]: https://s11.postimg.org/4b9e4jx1f/Screen_Shot_2016_12_03_at_16_05_51.png
arran_sheppard
Found the solution. If anyone is having the same issue and not seeing Themler or being able to edit through Wordpress, for me it was the WP-Config file.
Remove this line from the file: define('DISALLOW_FILE_EDIT', true);
Then save and replace. You should then have access.
Found the solution. If anyone is having the same issue and not seeing Themler or being able to edit through Wordpress, for me it was the WP-Config file. Remove this line from the file: define('DISALLOW_FILE_EDIT', true); Then save and replace. You should then have access.
Support Team posted this 05 December 2016
Nice to hear that the problem was solved. Feel free to contact us in any other occasion.
Hi, Nice to hear that the problem was solved. Feel free to contact us in any other occasion. Sincerely, Hella
