Bullet list define list-style-position
Stéphane
Stéphane posted this 30 November 2016
Actually it's position is set to be inside, but I would need it to be outside
How can I fix the list style to be
list-style-position : outside ;
Thanks in advance for your help and advise,
Best regards
Stéphane
Hi, Actually it's position is set to be `inside`, but I would need it to be `outside` How can I fix the list style to be list-style-position : outside ; Thanks in advance for your help and advise, Best regards Stéphane
9 Comments
Support Team posted this 30 November 2016
Unfortunately Themler does not have such built-in option. Please add the following code to the Themler Settings >> Additional CSS:
/* unordered list */
ul {
    list-style-position: outside;
/* ordered list */
ol {
Hi, Unfortunately Themler does not have such built-in option. Please add the following code to the Themler Settings >> Additional CSS: <pre> /* unordered list */ ul { list-style-position: outside; } /* ordered list */ ol { list-style-position: outside; } </pre> Thank you, Olivia
Stéphane
Thanks olivia !
Would suggest to add it to the features to be added to Themler.
Best regards
Stéphane
Thanks olivia ! Would suggest to add it to the features to be added to Themler. Best regards Stéphane
You're welcome.
Please note that this property works for bullet lists with default bullets (square, sircle, etc). It does not work with custom bullets.
I've added our suggestion to our wish list.
Hi, You're welcome. Please note that this property works for bullet lists with default bullets (square, sircle, etc). It does not work with custom bullets. I've added our suggestion to our wish list. Thank you, Olivia
redcosmicserpent
redcosmicserpent posted this 03 December 2016
I tried this solution but other css values seem to override the one you suggested, like this one:
.bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]) li, .bd-bulletlist li {
     list-style-position: inside;
How do I fix the css to make sure the 'outside' setting is used?
Hi, I tried this solution but other css values seem to override the one you suggested, like this one: .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]) li, .bd-bulletlist li { list-style-position: inside; } How do I fix the css to make sure the 'outside' setting is used? Thanks
Stéphane
Stéphane posted this 03 December 2016
What I have done is adding the !important attribute to get them outside like this :
.bd-bulletlist li, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul li {
  list-style-position : outside !important;
Hope it helps,
regards
Stéphane
> Hi, > > I tried this solution but other css values seem to override the one you suggested, like this one: > > .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul:not([class*="menu"]) li, .bd-bulletlist li { > list-style-position: inside; > } > > How do I fix the css to make sure the 'outside' setting is used? > > Thanks > Hi, What I have done is adding the `!important` attribute to get them outside like this : .bd-bulletlist li, .bd-tagstyles:not(.bd-custom-bulletlist):not(.shape-only) ul li { list-style-position : outside !important; } Hope it helps, regards Stéphane
redcosmicserpent
Great tip!
It helped me to work around the problem. :)
Thanks Stéphane!
It would still be nice though (and expected) to be able to do this inside themler. :|
Great tip! It helped me to work around the problem. :) Thanks Stéphane! It would still be nice though (and expected) to be able to do this inside themler. :|
Support Team posted this 05 December 2016
Thanks, we'll consider your suggestion.
Hi, Thanks, we'll consider your suggestion. Sincerely, Hella
walter.gasslbauer
walter.gasslbauer posted this 05 January 2017
Hello i tried this solution but it didn't Work in the Widget-Area. See de Attachment.
Stéphane
Stéphane posted this 05 January 2017
You have to adjust the css regarding your template.
use right-click inspect in Google chrome to get more information on which class .your class has to be modified...
.your class > the css code given a few messages above
refer to CSS selectors for good syntax : http://www.w3schools.com/cssref/css_selectors.asp
Stéphane
> Hello i tried this solution but it didn't Work in the Widget-Area. See de Attachment. > You have to adjust the css regarding your template. use right-click inspect in Google chrome to get more information on which class `.your class` has to be modified... .your class > the css code given a few messages above refer to CSS selectors for good syntax : http://www.w3schools.com/cssref/css_selectors.asp Regards, Stéphane
