Permament editions
pmsgotohell
pmsgotohell posted this 02 December 2016
Hello i start from saying i love themler realy much but there are few prestashop modules i worked really hard to adjust to themler.
Few of them require inclussion of:
{if isset($page_name)}{$page_name|escape:'htmlall':'UTF-8'}{/if}"> in body starter
Themler:
<body {if isset($page_name)}id {/if} class>
Should be:
multiple temple fiiles are making it terible every time i try to updatetheme. Is there a posibility to put such ad permamently?
Its needed for Core prestashop JS filles which most modules want to have
Hello i start from saying i love themler realy much but there are few prestashop modules i worked really hard to adjust to themler. Few of them require inclussion of: {if isset($page_name)}{$page_name|escape:'htmlall':'UTF-8'}{/if}"> in body starter Themler: &lt;body {if isset($page_name)}id {/if} class&gt; Should be: &lt;body {if isset($page_name)}id {/if} class&gt; multiple temple fiiles are making it terible every time i try to updatetheme. Is there a posibility to put such ad permamently? Its needed for Core prestashop JS filles which most modules want to have
Support Team posted this 02 December 2016
Unfortunately there is no possibility to edit that part of the theme inside the application and all the manual changes are overridden each time you save the theme.
Hi, Unfortunately there is no possibility to edit that part of the theme inside the application and all the manual changes are overridden each time you save the theme. Sincerely, Hella
pmsgotohell
is there posibility to make ovveride for it?
Support Team posted this 05 December 2016
No, the only way is to edit the theme each time you save it.
Hi, No, the only way is to edit the theme each time you save it. Sincerely, Hella
