Shortcodes in CMS Code Control
Liceo
Liceo posted this 02 December 2016
Hi there
Is there a way to insert 3th party plugin shortcodes in the CMS code control? Just copy/paste doesn't seem to work (see attachment).
martin
Hi there Is there a way to insert 3th party plugin shortcodes in the CMS code control? Just copy/paste doesn't seem to work (see attachment). Thanks martin
9 Comments
Support Team posted this 02 December 2016
Please use Shortcodes control to insert shortcodes.
Hi, Please use Shortcodes control to insert shortcodes. Thank you, Olivia
Malinka
Malinka posted this 02 December 2016
try this in CMS Code Control
<?php echo do_shortcode("[shortcode]"); ?>
or this &lt;?php echo do_shortcode(&#39;[shortcode]&#39;);?&gt;
Replace [shortcode] with your shortcode
Best regards
Malinka
Hi try this in CMS Code Control <?php echo do_shortcode("[shortcode]"); ?> or this `&lt;?php echo do_shortcode(&#39;[shortcode]&#39;);?&gt;` Replace [shortcode] with your shortcode Best regards Malinka
Malinka
Problem with last code here we go again.
<?php echo do_shortcode('[shortcode]'); ?>
Problem with last code here we go again. <?php echo do_shortcode('[shortcode]'); ?>
zzGreg
zzGreg posted this 02 December 2016
Malinka,
For me, I just use (in the Themler shortcode block):
[shortcode]
No php and it works for me. Perhaps it will work for you too. Goodluck.
Malinka, For me, I just use (in the Themler shortcode block): [shortcode] No php and it works for me. Perhaps it will work for you too. Goodluck.
Malinka
Think question was Shortcodes in CMS Code Control
Best regards
Malinka
Think question was Shortcodes in CMS Code Control Best regards Malinka
Liceo
Pretty cool, works! Thanks to all!
Jovanny hernandez
Jovanny hernandez posted this 06 January 2017
Ya encontré la respuesta,
<?php echo do_shortcode('[contact-form-7 id title ]');?>
Ya encontré la respuesta, &lt;?php echo do_shortcode(&#39;[contact-form-7 id title ]&#39;);?&gt;
Stagger Lee posted this 10 February 2018
This does not work anymore. Works on front-end, but in Themler editing screen it shows raw shortcode.
Support Team posted this 13 February 2018
I've tested it in Themler v438 and it works ok:
This is Contact Form 7 form.
Hi, I've tested it in Themler v438 and it works ok: !cms-code-form.png! This is Contact Form 7 form. Thank you, Olivia
