Menu
tpkarlen
tpkarlen posted this 02 December 2016
Help....
Anyone? Can't figure it out. Here's a screencast on my google drive
https://drive.google.com/file/d/0B-nyv909UW3nZDRKaVJHMzRwMjA/view?usp=sharing
Thanks in advance
Todd
Help.... Anyone? Can't figure it out. Here's a screencast on my google drive https://drive.google.com/file/d/0B-nyv909UW3nZDRKaVJHMzRwMjA/view?usp=sharing Thanks in advance Todd
shaulhadar
Is Solution
shaulhadar posted this 03 December 2016
Hi Todd, I saw your video...
First of all, for some reason you have the top menu, here there is a bug in themler , they didn't fix it yet...in this menu you actually can't change the size and color of the hamburger...
But don't worry, all you need to do is use the "horizontal menu" instead...
You will need to delete the top menu and insert a horizontal menu instead, there you will see all those options and they work well...
I hope you will succeed :) I also hope thmeler will fix this ASAP...
Hi Todd, I saw your video... First of all, for some reason you have the top menu, here there is a bug in themler , they didn't fix it yet...in this menu you actually can't change the size and color of the hamburger... But don't worry, all you need to do is use the "horizontal menu" instead... You will need to delete the top menu and insert a horizontal menu instead, there you will see all those options and they work well... I hope you will succeed :) I also hope thmeler will fix this ASAP...
Stagger Lee posted this 03 December 2016
I noticed Menus are missing "Ordered List" & "Bullet list" More styles options.
There are some options for links and "ul", "li" tags. Before I could make "li" tags 100% width and display: block. Now it is gone, impossible.
I noticed Menus are missing "Ordered List" & "Bullet list" More styles options. There are some options for links and "ul", "li" tags. Before I could make "li" tags 100% width and display: block. Now it is gone, impossible.
Support Team posted this 05 December 2016
Yes please, use the Horizontal Menu control as the Top Menu control is a secondary menu control.
@ Stagger, menus actually do not have more styles as they are not the content holders, they are the controls with a specific content ad that content options are available. So to set the 100% width for the li you can set the menu item width to 100%.
Hi, Yes please, use the Horizontal Menu control as the Top Menu control is a secondary menu control. @ Stagger, menus actually do not have more styles as they are not the content holders, they are the controls with a specific content ad that content options are available. So to set the 100% width for the `li` you can set the menu item width to 100%. Sincerely, Hella
tpkarlen
tpkarlen posted this 05 December 2016
Thanks Shaulhader :) And by the way, beautiful music that you create :)
> Hi Todd, I saw your video... > First of all, for some reason you have the top menu, here there is a bug in themler , they didn't fix it yet...in this menu you actually can't change the size and color of the hamburger... > > But don't worry, all you need to do is use the "horizontal menu" instead... > You will need to delete the top menu and insert a horizontal menu instead, there you will see all those options and they work well... > > I hope you will succeed :) I also hope thmeler will fix this ASAP... Thanks Shaulhader :) And by the way, beautiful music that you create :)
shaulhadar
shaulhadar posted this 06 December 2016
Thanks for listening to my music Todd, and i am happy to know i could help :)
