Captcha in Themler Forms
Marco
Marco posted this 06 December 2016
Hi Guys,
have added a new form with help of your form controls inside my html webpage.
It also works, but:
HOW can I add recaptcha?
Where to place the code snippet?
thx in advance
Hi Guys, have added a new form with help of your form controls inside my html webpage. It also works, but: HOW can I add recaptcha? Where to place the code snippet? thx in advance
Support Team posted this 07 December 2016
Please follow the guides from google on how to implement the captcha. The <script> part should be included under the Home >> Settings >> Additional HEAD HTML. Then insert the code using the HTML control. Maybe you will need to edit the code of the exported theme manually.
Hi, Please follow the guides from google on how to implement the captcha. The `<script>` part should be included under the Home >> Settings >> Additional HEAD HTML. Then insert the code using the HTML control. Maybe you will need to edit the code of the exported theme manually. Sincerely, Hella
raffe
raffe posted this 07 February 2019
Hello Marco,
Have you been able to combine reCAPTCHA with Form?
Hello Marco, Have you been able to combine reCAPTCHA with Form? Thank you
raffe
Hi Guys,
It also works, but:
thx in advance
Hello Marco,
> Hi Guys, > have added a new form with help of your form controls inside my html webpage. > It also works, but: > > HOW can I add recaptcha? > Where to place the code snippet? > > thx in advance Hello Marco, Have you been able to combine reCAPTCHA with Form? Thank you
raffe
raffe posted this 27 March 2019
Hi Guys,
It also works, but:
thx in advance
Did you manage to connect Form with reCAPTCHA?
> Hi Guys, > have added a new form with help of your form controls inside my html webpage. > It also works, but: > > HOW can I add recaptcha? > Where to place the code snippet? > > thx in advance Hello, Did you manage to connect Form with reCAPTCHA?
