CMS Content lenght
HDWeb
HDWeb posted this 06 December 2016
I cant figure out how to set CMS Content post to be full width, please give me some tip, it work on template post but in CMS content is not full width.
Its joomla CMS.
I cant figure out how to set CMS Content post to be full width, please give me some tip, it work on template post but in CMS content is not full width. Its joomla CMS. Thanks
Support Team posted this 07 December 2016
Could you please specify - on what template the full width doesn't work? Did you please try to add the "Wide Layout" extension to the post?
Hello, Could you please specify - on what template the full width doesn't work? Did you please try to add the "Wide Layout" extension to the post? Sincerely, Nettie, BillionDigital Team
HDWeb
HDWeb posted this 07 December 2016
In CMS content, example section with image in Template:Post is full width screen, but when I copy it to CMS content then its not. I attach two pictures for example.
I fix problem with custom templates from link http://answers.themler.com/articles/10804/how-to-create-and-use-custom-templates, but that is not solution in future. I want to use as CMS content.
In pictures are two the same section one in Template:Post , one in CMS content. I want to be the same in CMS content.
In CMS content, example section with image in Template:Post is full width screen, but when I copy it to CMS content then its not. I attach two pictures for example. I fix problem with custom templates from link http://answers.themler.com/articles/10804/how-to-create-and-use-custom-templates, but that is not solution in future. I want to use as CMS content. In pictures are two the same section one in Template:Post , one in CMS content. I want to be the same in CMS content.
Support Team posted this 08 December 2016
Go to the Home >> Settings and set the desktop width to 1920 px or more. If that does not help, attach your theme .
Hi, Go to the Home >> Settings and set the desktop width to 1920 px or more. If that does not help, attach your theme . Sincerely, Hella
