Wordpress disable pagination
BeatM
BeatM posted this 07 December 2016
how can I disable pagination below posts ?
Thanks !
Hi how can I disable pagination below posts ? Thanks !
Malinka
Is Solution
Malinka posted this 07 December 2016
Hope this image can help you disable pagination in posts.
Best regards
Malinka
Hi Hope this image can help you disable pagination in posts. Best regards Malinka
BeatM
BeatM posted this 06 April 2017
Hi Malinka - thanks a lot ! Just got into that again. Your solution works fine.
wendy.rose.au
wendy.rose.au posted this 02 May 2018
Hi. I have set my pagination to show "none" but it still shows on my page (post).
Any help would be great. Thanks
Hi. I have set my pagination to show "none" but it still shows on my page (post). Any help would be great. Thanks
Support Team posted this 02 May 2018
Do you use Joomla? Have you disabled it globally? If so, please check if the setting is set to Hidden also for a specific menu item.
Also please clear caches after this.
Hello, Do you use Joomla? Have you disabled it globally? If so, please check if the setting is set to Hidden also for a specific menu item. Also please clear caches after this. Sincerely, Nettie, BillionDigital Team
