Change menu aspect in sticky header
loppini
loppini posted this 11 December 2016
Is it possibile to change the aspect of the horizontal menu when the page is scrolled? The horizontal menu is in a sticky header, and I can change the aspect of the header when the page is scrolled, but I can find the way to change the aspect of the horizontal menu.
The effect that i want is this:
http://www.braccianositiweb.it/paint2 (try to scroll and you can see that the menu change the colors)
The site where I am working is this:
http://www.braccianositiweb.it/paint3
Is it possibile to change the aspect of the horizontal menu when the page is scrolled? The horizontal menu is in a sticky header, and I can change the aspect of the header when the page is scrolled, but I can find the way to change the aspect of the horizontal menu. The effect that i want is this: http://www.braccianositiweb.it/paint2 (try to scroll and you can see that the menu change the colors) The site where I am working is this: http://www.braccianositiweb.it/paint3 Thanks
11 Comments
Support Team posted this 13 December 2016
Hello Francesco,
I'm not quite sure that I see what you mean. Do you mean that you'd like to add a little move for the menu and image when the page scrolls and background of menu area is changed to white?
Hello Francesco, I'm not quite sure that I see what you mean. Do you mean that you'd like to add a little move for the menu and image when the page scrolls and background of menu area is changed to white? regards, Aileen
loppini
loppini posted this 13 December 2016
No, I want to change the color of the text of the horizontal menĂ¹, from White to other colors
No, I want to change the color of the text of the horizontal menù, from White to other colors
There is no such option in Themer, but you can use the following code:
.affix nav li span {
    color: #000000;
add it under the Home >> Settings >> Additional CSS.
Hi, There is no such option in Themer, but you can use the following code: .affix nav li span { color: #000000; } add it under the Home >> Settings >> Additional CSS. Sincerely, Hella
loppini
loppini posted this 14 December 2016
It works!
Thank you so much!
It works! Thank you so much!
Support Team posted this 14 December 2016
loppini
loppini posted this 31 October 2017
Hello, I used the code suggested (.affix nav li span { color: #000000;} and it works fine.
But there is a problem: this code change also the color of the submenus. How can I maintain the color of the submenus (without changes) in the sticky header?
Hello, I used the code suggested (.affix nav li span { color: #000000;} and it works fine. But there is a problem: this code change also the color of the submenus. How can I maintain the color of the submenus (without changes) in the sticky header?
Support Team posted this 31 October 2017
Try this one:
.affix nav > li span {
    color: #000000;
Hi, Try this one: .affix nav > li span { color: #000000; } Sincerely, Hella
loppini
loppini posted this 05 November 2017
Unfortunately seems doesn't work... with this the color of the text of the horizontal menĂ¹ (first level) don't change when the page scrolls
Hello, Unfortunately seems doesn't work... with this the color of the text of the horizontal menù (first level) don't change when the page scrolls
Support Team posted this 08 November 2017
Please try something like this:
.affix nav[class*="bd-hmenu"] .nav > li[class*="bd-menuitem"] > a > span {
color: red;
This is more strong selector. It should affect parents only.
But it will override hover color. In addition to his you will need second declaration of hover state color.
.affix nav[class*="bd-hmenu"] .nav > li[class*="bd-menuitem"]:hover > a > span {
color: blue;
Hi, Please try something like this: `.affix nav[class*="bd-hmenu"] .nav > li[class*="bd-menuitem"] > a > span { color: red; }` This is more strong selector. It should affect parents only. But it will override hover color. In addition to his you will need second declaration of hover state color. `.affix nav[class*="bd-hmenu"] .nav > li[class*="bd-menuitem"]:hover > a > span { color: blue; }` Thank you, Olivia
loppini
loppini posted this 17 November 2017
It works!
Great!
It works! Great!
Support Team posted this 19 November 2017
