prestashop multistore
deevando
deevando posted this 11 December 2016
I have multistore enabled in prestashop.
When i edit the template in the first store is not problem, but after select the second one and try to edit the template i get this error:
Sorry, error occurred. Your project will be restored.
Thanks.
Hi, I have multistore enabled in prestashop. When i edit the template in the first store is not problem, but after select the second one and try to edit the template i get this error: Sorry, error occurred. Your project will be restored. Thanks.
deevando
Its happen with safari.. I have try with firefox and its ok, but online edit with firefox is slower that safari.. Any option i need to change in safari to work?
Thanks.
Its happen with safari.. I have try with firefox and its ok, but online edit with firefox is slower that safari.. Any option i need to change in safari to work? Thanks.
deevando
I have try with Safari Technology Preview and the error show is..
"Unable to display external pages in preview. Themler has origin 'www.deevando.es', while preview is trying to open 'www.gamdias.es'
In multistore prestashop we have configured to domains one for each store... deevando.es, and gamdias.es
Principal domain is deevando.es and here it work, but when change to gamdias store the error is showed.
I have try with Safari Technology Preview and the error show is.. "Unable to display external pages in preview. Themler has origin 'www.deevando.es', while preview is trying to open 'www.gamdias.es' In multistore prestashop we have configured to domains one for each store... deevando.es, and gamdias.es Principal domain is deevando.es and here it work, but when change to gamdias store the error is showed.
Sorry for the delay.
Does the issue happen with Chrome?
The PS admin panel URL and shop URL should match. It's related to protocol also (http/https).
In your case, to work with shop1 you should access admin panel by shop1/admin URL. For shop2 you should access admin panel by shop2/admin URL.
Themler Team
Hi, Sorry for the delay. > Its happen with safari.. I have try with firefox and its ok, but online edit with firefox is slower that safari.. Any option i need to change in safari to work? Does the issue happen with Chrome? > In multistore prestashop we have configured to domains one for each store... deevando.es, and gamdias.es Principal domain is deevando.es and here it work, but when change to gamdias store the error is showed. The PS admin panel URL and shop URL should match. It's related to protocol also (http/https). In your case, to work with *shop1* you should access admin panel by *shop1/admin* URL. For *shop2* you should access admin panel by *shop2/admin* URL. Thank you, Themler Team
