Design Userprofil with Themler
MJ68
MJ68 posted this 15 December 2016
i want to design the userprofil which comes from MagicMember Plugin.
In Themler it will be shown as HTML Box.
I want to know that it is possible to edit these Layout with Themler?
On HTML Box can it change?
Or can i edit with CSS for this Page only?
Or is this nothing to with Themler?
Michael
Hi, i want to design the userprofil which comes from MagicMember Plugin. In Themler it will be shown as HTML Box. !UserProfil-HTML.png! I want to know that it is possible to edit these Layout with Themler? On HTML Box can it change? !UserProfil-HTML-Box.png! Or can i edit with CSS for this Page only? !UserProfil-HTML-CSS-Box.png! Or is this nothing to with Themler? Thanks Michael
9 Comments
Support Team posted this 15 December 2016
You can not edit the layout of the form as it is added with the shortcode and the code of the form itself comes from the outside source. You can add the style code to edit the design.
Hi, You can not edit the layout of the form as it is added with the shortcode and the code of the form itself comes from the outside source. You can add the style code to edit the design. Sincerely, Hella
MJ68
Hi Hella,
The Style Code will not work when used in the CSS-Box for that HTML.
I made the text red, but ist doest work.
It will be work only when i putt the CSS-Cosde into the "Additional-CSS"
Hi Hella, The Style Code will not work when used in the CSS-Box for that HTML. I made the text red, but ist doest work. It will be work only when i putt the CSS-Cosde into the "Additional-CSS"
Hello Michael,
in fact custom CSS should work if it is added to the CCS Code part of HTML control. If you want us to check this issue please provide access to your WP admin back and and note what page demonstrates the issue.
Hello Michael, in fact custom CSS should work if it is added to the CCS Code part of HTML control. If you want us to check this issue please provide access to your WP admin back and and note what page demonstrates the issue. regards, Aileen
MJ68
MJ68 posted this 19 December 2016
https://abnehmen-ganz-einfach.info/bearbeiten
user: millionHelp
PW: Dx^iumktdPdJukOwyxdOgNV4
Page : Benutzerprofil
https://abnehmen-ganz-einfach.info/bearbeiten user: millionHelp PW: Dx^iumktdPdJukOwyxdOgNV4 Page : Benutzerprofil Thanks
Support Team posted this 20 December 2016
Hi Michael,
how I could access the page mentioned on the screenshot
http://attachments.answers.billiondigital.com/878/22878/UserProfil-HTML.png
I cannot find a link to in anywhere at the site.
Hi Michael, how I could access the page mentioned on the screenshot http://attachments.answers.billiondigital.com/878/22878/UserProfil-HTML.png ? I cannot find a link to in anywhere at the site. regards, Aileen
MJ68
MJ68 posted this 20 December 2016
Hi Aileen,
i can't find it to.
Then i want to ask how works the HTML or CSS Windows for these Page.
Hi Aileen, i can't find it to. Then i want to ask how works the HTML or CSS Windows for these Page.
Support Team posted this 21 December 2016
Hello Michael,
you just use custom html and css code in Edit HTML, e.g.
Then add custom CSS class under Edit CSS
and here is the result
Hello Michael, you just use custom html and css code in Edit HTML, e.g. !EditHTML.png! Then add custom CSS class under Edit CSS !EditCSS.png! and here is the result !HTMLRes.png! regards, Aileen
MJ68
MJ68 posted this 21 December 2016
Thank you.
Thats very nice and will help.
Michael
Thank you. Thats very nice and will help. Michael
You are welcome. Feel free to contact us again.
You are welcome. Feel free to contact us again. Sincerely, Hella
