buttons half in a slider
arawolf
arawolf posted this 15 December 2016
a client of me want to have the 5 squares under the slider replaced half in the slider (attach 2) How can i do these.
12 Comments
Support Team posted this 16 December 2016
I'm attaching an example of the Section with 5 columns and negative margin. Please put it below the Slider or something to see the result.
Hi, I'm attaching an example of the Section with 5 columns and negative margin. Please put it below the Slider or something to see the result. Please keep us posted about the progress. Thank you, Olivia
arawolf
arawolf posted this 16 December 2016
how can i get the section in the template
arawolf
i put a negativ marge to the section, but it increase, may be i have to put a number to the z-ndex. But it doesn't work.
Add blank or any other section and then use the load option to import the section from the attached .zip file.
Hi, Add blank or any other section and then use the load option to import the section from the attached .zip file. Sincerely, Hella
arawolf
Sorry a get a error message. It's a joomla site Maybe some more explanation. The slider is in the header, the columns not.
Hello Kris,
I'm sorry but the issue is not clear for me. Could you please describe it in more details?
Hello Kris, I'm sorry but the issue is not clear for me. Could you please describe it in more details? Regards, Aileen
arawolf
arawolf posted this 19 December 2016
The client want to have the 5 squares ( with the buttons attachment 1 ) half in the slider ( just like the squares in attachment 2) So i change the margin from the section with the squares negative but the section don't go above the slider.
Support Team posted this 21 December 2016
Hello Kris,
please export the theme with options 'Include Content' , 'Include Themler...' and attach it here. Note that page name where you'd added the 5 squares.
Hello Kris, please export the theme with options 'Include Content' , 'Include Themler...' and attach it here. Note that page name where you'd added the 5 squares. regards, Aileen
arawolf
arawolf posted this 21 December 2016
it's in the header
it's in the header
Support Team posted this 22 December 2016
Hello Kris,
please follow the steps:
1.remove empty Section located right under Header;
2.select the Section with columns and set its background color to transparent
3.open the Section options and set
Position: relative
z-index:1000
4.set margin-top of this section to negative value, e.g.
-50px
5.select Columns one by one and specify the background color
I'm attaching the modified theme just in case
Hello Kris, please follow the steps: 1.remove empty Section located right under Header; 2.select the Section with columns and set its background color to transparent 3.open the Section options and set Position: relative z-index:1000 4.set margin-top of this section to negative value, e.g. -50px 5.select Columns one by one and specify the background color I'm attaching the modified theme just in case Regards, Aileen
arawolf
arawolf posted this 22 December 2016
thnxs it's working perfect. Just a question : why z-index 1000
You commonly take some high value so nothing else will be greater and could overlap it.
Hi, You commonly take some high value so nothing else will be greater and could overlap it. Sincerely, Hella
