Geodirectory wordpress plugin
Malinka
Malinka posted this 17 December 2016
I wonder if someone can help me make https://sv.wordpress.org/plugins/geodirectory/ Compatible with themler or point me in the right direction.
Here you can find a themler setup with Geodirectory:
http://192.185.30.207/~themler/
If you click GD Home page menu you see all themler styles is gone.
Best Regards
Malinka
Hi I wonder if someone can help me make https://sv.wordpress.org/plugins/geodirectory/ Compatible with themler or point me in the right direction. Here you can find a themler setup with Geodirectory: http://192.185.30.207/~themler/ If you click GD Home page menu you see all themler styles is gone. Best Regards Malinka
17 Comments
ike
ike posted this 19 December 2016
I am having the exact same problem. Any guidance on this would be great! I have a huge project that I am working on and this is a key feature to the entire project.
Malinka
Malinka posted this 19 December 2016
If i manage to solve this i will update you here.
Best regards
Malinka
If i manage to solve this i will update you here. Best regards Malinka
I'm not sure why the theme is not working, maybe you need to set some settings in the plug-in to use the theme styles.
Also in the plug-in page it's written that you can contact the plug-in developer for the help with the theme:
https://wordpress.org/support/plugin/geodirectory
Hi, I'm not sure why the theme is not working, maybe you need to set some settings in the plug-in to use the theme styles. Also in the plug-in page it's written that you can contact the plug-in developer for the help with the theme: https://wordpress.org/support/plugin/geodirectory Sincerely, Hella
ike
I actually reached out to the developer as well. The response I got was "the theme does not even work with GD de-activated so there is nothing we can do."
The site I am looking at is driftlessdestinations.us click on restaurants and the Sparta Family Restaurant you will see the template just essentially disappears.
Ike
I actually reached out to the developer as well. The response I got was "the theme does not even work with GD de-activated so there is nothing we can do." The site I am looking at is driftlessdestinations.us click on restaurants and the Sparta Family Restaurant you will see the template just essentially disappears. Ike
Malinka
i managed to fix gd-home template http://192.185.30.207/~themler/gd-home/
You have to put geodirectory folder in root and then copy geodirectory templates to that location to override geodirectory templates.
Themler team can you inspect code and tell if this is proper way to make Themler Compatible with Geodirectory plugin.
I can send you login info.
Best Regards
Malinka
Hi i managed to fix gd-home template http://192.185.30.207/~themler/gd-home/ You have to put geodirectory folder in root and then copy geodirectory templates to that location to override geodirectory templates. Themler team can you inspect code and tell if this is proper way to make Themler Compatible with Geodirectory plugin. I can send you login info. Best Regards Malinka
ike
Malinka,
Are you putting the GD templates in the root of the site, or the root of the template?
Also the geo directory team said that they would put together some customization tomorrow to make it work with this theme, now I don't know if they will share how they did it, or if it will work with all Themler twmplates, so I did ask those questions. They have been extremely responsive so far though, and this is why you pay for a liscense. Its good to see their team is actively working through issues. I hope they come up with something that works against Themler in general.
Malinka, Are you putting the GD templates in the root of the site, or the root of the template? Also the geo directory team said that they would put together some customization tomorrow to make it work with this theme, now I don't know if they will share how they did it, or if it will work with all Themler twmplates, so I did ask those questions. They have been extremely responsive so far though, and this is why you pay for a liscense. Its good to see their team is actively working through issues. I hope they come up with something that works against Themler in general.
Malinka
I used this guide: https://wpgeodirectory.com/docs/customizing-geodirectory-templates/
Best Regards
Malinka
I used this guide: https://wpgeodirectory.com/docs/customizing-geodirectory-templates/ Best Regards Malinka
Malinka
Problem is my solution only work on my specific theme. We need a solution that works on all Themler themes.
If you want to see how i did with gd-home template i can send you the file.
Hi Problem is my solution only work on my specific theme. We need a solution that works on all Themler themes. If you want to see how i did with gd-home template i can send you the file.
Malinka
The easiest solution is to make a page template and include cms control and paste the code from attached file. Should work for all kind of themler theme
ike
ike posted this 20 December 2016
I actually reached out to the developer as well. Their response has been good, and they are trying however are still running into issues. This seems to happen often with Themler themes as I ran into the same problem with a calendar plug-in. Its frustrating and I'm not sure if I'm setting something up wrong or if it's themler. I did alot of Joomla and never had these issues, but with WordPress it seems to be constant.
Ike
> I actually reached out to the developer as well. Their response has been good, and they are trying however are still running into issues. This seems to happen often with Themler themes as I ran into the same problem with a calendar plug-in. Its frustrating and I'm not sure if I'm setting something up wrong or if it's themler. I did alot of Joomla and never had these issues, but with WordPress it seems to be constant. > > The site I am looking at is driftlessdestinations.us click on restaurants and the Sparta Family Restaurant you will see the template just essentially disappears. > > Ike
ike
I would agree 100% I don't understand why from time to time we run into this issue if all wordpress plugins are built on the same standards,
> Hi > > Problem is my solution only work on my specific theme. We need a solution that works on all Themler themes. > > If you want to see how i did with gd-home template i can send you the file. I would agree 100% I don't understand why from time to time we run into this issue if all wordpress plugins are built on the same standards,
ike
So I did this, and I'm really close, however I'm missing the header and footer, (not sure about the sidebars yet) any ideas? My menus, logo, social icons etc are all in the header so kind of important to be in there.
> The easiest solution is to make a page template and include cms control and paste the code from attached file. Should work for all kind of themler theme So I did this, and I'm really close, however I'm missing the header and footer, (not sure about the sidebars yet) any ideas? My menus, logo, social icons etc are all in the header so kind of important to be in there.
Malinka
Malinka posted this 21 December 2016
I will have developer look in to this but in 2017.
I will post here when done.
Best regards
Malinka
I will have developer look in to this but in 2017. I will post here when done. Best regards Malinka
Malinka
Malinka posted this 21 January 2017
From this post i managed to solve geodirectory problem
http://answers.themler.com/questions/40629/wp-knowledgebase
Important is to add header.php and footer.php to root of your theme. In the link above you can read 2 ways to make the files.
Best Regards
Malinka
Hi From this post i managed to solve geodirectory problem http://answers.themler.com/questions/40629/wp-knowledgebase Important is to add header.php and footer.php to root of your theme. In the link above you can read 2 ways to make the files. Best Regards Malinka
Malinka
Malinka posted this 10 May 2017
Here you can see a site with Geodirectory wordpress plugin and Themler:
http://unnaryd.se/
Best regards
Malinka
Hi Here you can see a site with Geodirectory wordpress plugin and Themler: http://unnaryd.se/ Best regards Malinka
Malinka
Malinka posted this 17 December 2017
Themler have Added header.php and footer.php files now wpgeodirectory works great.
I have managed to develope a wpgeodirectory site very fast with no hassles.
lssassistansen.se
Best regards
Malinka
Themler have Added header.php and footer.php files now wpgeodirectory works great. I have managed to develope a wpgeodirectory site very fast with no hassles. [lssassistansen.se][1] [1]: https://lssassistansen.se/ Best regards Malinka
Malinka
Malinka posted this 29 May 2019
There has been an update to geodirectory where everything works without having to customize the theme. Only thing not to forget is in themler setting page wp-admin/themes.php?page=functions.php . Dont check "Use auto excerpts " because geodirectory will fail to output content.
This site is done with Geodirectory v2 Coach Förbundet
There has been an update to geodirectory where everything works without having to customize the theme. Only thing not to forget is in themler setting page wp-admin/themes.php?page=functions.php . Dont check "Use auto excerpts " because geodirectory will fail to output content. This site is done with Geodirectory v2 [Coach Förbundet][1] [1]: https://xn--coachfrbundet-nmb.se/
