Is Themler compatible with WPML?
info1841
info1841 posted this 19 December 2016
I would like to create a multilingual website with Themler. Is Themler compatible with WPML? Which language plugin would you recommend?
Yes, Themler should work fine with it. Feel free to try and contact us in case of any issues.
Hi, Yes, Themler should work fine with it. Feel free to try and contact us in case of any issues. Sincerely, Hella
info.annahanna
info.annahanna posted this 20 January 2017
Dear Hella,
I would like to dive a bit deeper into the question asked above. I also use themler for wordpress including the woocommerce plugin. And I now want to make my site multilingual. I am looking into WPML too. You say it must work fine, but is this also true when, like in our case, you write several content within the themler environment? Pls. let me know soon.
Hannah
Dear Hella, I would like to dive a bit deeper into the question asked above. I also use themler for wordpress including the woocommerce plugin. And I now want to make my site multilingual. I am looking into WPML too. You say it must work fine, but is this also true when, like in our case, you write several content within the themler environment? Pls. let me know soon. Sincerely, Hannah
Support Team posted this 23 January 2017
Hello Hannah,
in WP admin back end you create different content for different languages. Then in Themler and on live site different content is displayed depending on selected language.
Regarding the static content created in Themler. It cannot be "translated" inside Themler. I'd recommend that you replace all static content with dynamic content. For example instead of Text Control add Widget Area control and on WP admin back end locate Text Widget inside this widget area. Because text widget output translated text for different languages.
Hello Hannah, in WP admin back end you create different content for different languages. Then in Themler and on live site different content is displayed depending on selected language. Regarding the static content created in Themler. It cannot be "translated" inside Themler. I'd recommend that you replace all static content with dynamic content. For example instead of Text Control add Widget Area control and on WP admin back end locate Text Widget inside this widget area. Because text widget output translated text for different languages. regards, Aileen
