Style Joomla Print Popup Window
DaveOzric
DaveOzric posted this 21 December 2016
Hello, I would like to change a few things in the default Joomla popup window that appears when you click on print in an article. Specifically the title color and Print Coupon text color and size.
Is there a way to add this to the default custom css?
Hello, I would like to change a few things in the default Joomla popup window that appears when you click on print in an article. Specifically the title color and Print Coupon text color and size. Is there a way to add this to the default custom css? Thank you !2016-12-21-175510.jpg!
8 Comments
Support Team posted this 22 December 2016
Themler does not have an option to design the print view. You can try to copy the template.css code into the print.css file.
Hi, Themler does not have an option to design the print view. You can try to copy the `template.css` code into the `print.css` file. Sincerely, Hella
DaveOzric
DaveOzric posted this 22 December 2016
Hello, can I just target these few things in my custom css? I mean you can override 3rd party css doing it that way?
I looked at the print.css and it's a large file so I am not sure it's the right one.
Hello, can I just target these few things in my custom css? I mean you can override 3rd party css doing it that way? I looked at the print.css and it's a large file so I am not sure it's the right one. Thanks
Support Team posted this 23 December 2016
I'm not sure about that. Please refer to the Joomla documentation about the print styles as Themler does not control it.
Hi, I'm not sure about that. Please refer to the Joomla documentation about the print styles as Themler does not control it. Sincerely, Hella
DaveOzric
DaveOzric posted this 23 December 2016
So the print styles are not in the Themler print.css file for this popup window?
Hello Dave,
please provide the direct link to the page which demonstrates the issue with pop up window style.
Hello Dave, please provide the direct link to the page which demonstrates the issue with pop up window style. Regards, Aileen
DaveOzric
http://silverspringautomotive.ecowebdesign.com/specials/29-4-wheel-alignment-check-39-95?tmpl=component&componentStyle=blog_3&print=1&layout=default&page=
DaveOzric
This is the actual popup in it's own window.
Support Team posted this 26 December 2016
Hello Dave,
the pop up windows (as well as print type windows) are using the style file print.css, while the standard page uses the template.css file. The print.css is pretty truncated version of theme style, it includes the basic styles only.
You may consider customizing the print template pop up on Joomla end, like it is described in the article
https://docs.joomla.org/Customizing_the_print_pop-up
Hello Dave, the pop up windows (as well as print type windows) are using the style file print.css, while the standard page uses the template.css file. The print.css is pretty truncated version of theme style, it includes the basic styles only. You may consider customizing the print template pop up on Joomla end, like it is described in the article https://docs.joomla.org/Customizing_the_print_pop-up regards, Aileen
