Problem with Eventbrite API and Theme
jcamino
jcamino posted this 22 December 2016
Hello. I just installed the Eventbrite API to my theme (made with Themler) and the plugin works fine showing my events on my website. BUT the events page does not match the rest of the website theme. I try to do all the steps recommended on this website: https://themeshaper.com/2014/12/08/working-with-the-eventbrite-api-plugin/ but, as I´m not a theme developer (that is why I use Themler...), I could not.
My website is: www.barkuscoach.com and the events page link is: http://barkuscoach.com/eventos-empresariales/. You you know how to solve this incompatibility issue of the plugin with Themler?. Thanks in advance.
Hello. I just installed the Eventbrite API to my theme (made with Themler) and the plugin works fine showing my events on my website. BUT the events page does not match the rest of the website theme. I try to do all the steps recommended on this website: https://themeshaper.com/2014/12/08/working-with-the-eventbrite-api-plugin/ but, as I´m not a theme developer (that is why I use Themler...), I could not. My website is: www.barkuscoach.com and the events page link is: http://barkuscoach.com/eventos-empresariales/. You you know how to solve this incompatibility issue of the plugin with Themler?. Thanks in advance.
Support Team posted this 22 December 2016
Actually the implementation of the plug-in to support the theme is really complicated and you can try to contact the plug-in developer so they could help you implement the the theme support.
Hi, Actually the implementation of the plug-in to support the theme is really complicated and you can try to contact the plug-in developer so they could help you implement the the theme support. Sincerely, Hella
