DNN skins - active menu items
12.madu
12.madu posted this 30 December 2016
I used Themler to create a DNN theme.
I want a different color and different color underline for the active menu item. I selected "active" state and applied it. But it is not loading on the theme. This is not working. Please, can you check this and can you advise us please?
Thanks!
I used Themler to create a DNN theme. I want a different color and different color underline for the active menu item. I selected "active" state and applied it. But it is not loading on the theme. This is not working. Please, can you check this and can you advise us please? Thanks!
jos
jos posted this 02 January 2017
I also use the DNN theme.
I'm also struggeling with the underline color for the active state but than for a text link.
This is also not working.
I also use the DNN theme. I'm also struggeling with the underline color for the active state but than for a text link. This is also not working.
Support Team posted this 09 January 2017
For first level items you can try adding native DDR menu token to the menu:
- open \Portals\_default\Skins\menu_test\Menu_2\SimpleTokens.txt file
- find the TOP level items and add SELECTED token with active class:
[?SELECTED] class="active"[/?]
For example:
<a href="[=URL]" [?TARGET]target="[=TARGET]" [/?] [?SELECTED] class="active"[/?]>[=TEXT]</a>
This should help.
jos,
What exactly links you're referring to?
Hi, For first level items you can try adding native DDR menu token to the menu: - open `\Portals\_default\Skins\menu_test\Menu_2\SimpleTokens.txt` file - find the TOP level items and add SELECTED token with active class: `[?SELECTED] class="active"[/?]` For example: `<a href="[=URL]" [?TARGET]target="[=TARGET]" [/?] [?SELECTED] class="active"[/?]>[=TEXT]</a>` This should help. **jos**, What exactly links you're referring to? Thank you, Olivia
