no run themler
dmintermedia
dmintermedia posted this 02 January 2017
hello, I can not run the program from a computer program is loading all the time but it does not appear in the home page can only website :http://localhost:12080/themler_1911410065/startup/
15 Comments
Support Team posted this 09 January 2017
Sorry for the delay. Please try the following suggestions:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting
Hi, Sorry for the delay. Please try the following suggestions: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting Sincerely, Hella
dmintermedia
dmintermedia posted this 09 January 2017
the problem lies not with the firewall or anti-virus because it does not work well on the disabled deny and off antivirus
Seppe
Seppe posted this 09 January 2017
Same issue here all day
Tried all possible solutions from the troubleshooting-guide.
I always get a blank page.
Greetings
Same issue here all day Tried all possible solutions from the troubleshooting-guide. I always get a blank page. Greetings
dmintermedia
dmintermedia posted this 10 January 2017
when you try to start sending screen appears in the appendix and the program does not start
Seppe
Seppe posted this 10 January 2017
I have more or less the same.
Even the spirals are not showing up on my screen.
Anyhow, I'm also still waiting for an answer from support.............
I have more or less the same. Even the spirals are not showing up on my screen. Anyhow, I'm also still waiting for an answer from support.............
dmintermedia
dmintermedia posted this 11 January 2017
if the problem has already been solved? send your diagnostic or other?
dpeteroff
dpeteroff posted this 11 January 2017
Same issue, loading all the time but it does not appear... @Google Chrome (55.0.2883.75).
"it is not the browser", this is it between working and not working, not updated
log console chrome:
  • Application Cache Error event: Manifest fetch failed (4) ..../manifest/355.manifest
  • Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience.
  • DevTools failed to parse SourceMap: ...../editor/app/frontend/html/Intl.min.js.map
  • Refused to execute script from '...../editor/null' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
Same issue, loading all the time but it does not appear... @Google Chrome (55.0.2883.75). "it is not the browser", this is it between working and not working, not updated log console chrome: - Application Cache Error event: Manifest fetch failed (4) ..../manifest/355.manifest - Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. - DevTools failed to parse SourceMap: ...../__editor__/app/frontend/html/Intl.min.js.map - Refused to execute script from '...../__editor__/null' because its MIME type ('text/html') is not executable, and strict MIME type checking is enabled.
dpeteroff
the apache Document Root begins at "/themes/'THEMENAME'_Home", but the manifest file begins directory previously.
this is the problem
the apache Document Root begins at "/themes/'THEMENAME'_Home", but the manifest file begins directory previously. this is the problem
dpeteroff
solved
removed from apache:
apache ErrorDocument 404 http://www.HOST.com
So I had casually put an 404 referrer .. again removed this, and it works good again.
solved removed from apache: apache ErrorDocument 404 http://www.HOST.com So I had casually put an 404 referrer .. again removed this, and it works good again.
dmintermedia
I do not know the technical matters as I remove the "removed from apache:
apache ErrorDocument 404 http://www.HOST.com " ?
please explain step by step
I do not know the technical matters as I remove the "removed from apache: apache ErrorDocument 404 http://www.HOST.com " ? please explain step by step
Support Team posted this 13 January 2017
Could you please try opening page
in browser. Does it work?
The numbers are different for each Themler installation. The exact number can be found here:
c:\ProgramData\Themler\hd_data\themler_[these_numbers]\
Hi, Could you please try opening page `http://localhost:12080/themler_1911410065/startup/` in browser. Does it work? The numbers are different for each Themler installation. The exact number can be found here: `c:\ProgramData\Themler\hd_data\themler_[these_numbers]\` Thank you, Olivia
dmintermedia
dmintermedia posted this 13 January 2017
the address http: // localhost: 12080 / themler_1911410065 / startup / program starts up but no computer, sending diagnostics themler
how to run it on your computer is not a browser?
the address http: // localhost: 12080 / themler_1911410065 / startup / program starts up but no computer, sending diagnostics themler how to run it on your computer is not a browser?
Support Team posted this 17 January 2017
There is no difference whether you start Themler Desktop or http://localhost:12080/themler_1911410065/startup/ page in browser. Themler Desktop includes browser and it opens the same. You just do not see the address.
We'll check the reported issue. In the meantime please use Themler in browser using the provided link if it works ok on your side.
Hi, There is no difference whether you start Themler Desktop or `http://localhost:12080/themler_1911410065/startup/` page in browser. Themler Desktop includes browser and it opens the same. You just do not see the address. We'll check the reported issue. In the meantime please use Themler in browser using the provided link if it works ok on your side. Thank you, Olivia
dmintermedia
dmintermedia posted this 17 January 2017
Themler starts with http: // localhost: 12080 / themler_1911410065 / startup /
then moves to address http://127.0.0.1:12080/themler_1911410065/joomla/administrator/index.php?option=com_templates&view=style&layout=edit&id=10&editor=1&theme=untitled&login=admin&password=admin&domain=http%3A%2F%2Fthemler. com & ver = 1 & startup = true & desktop = true
but does not start the computer (I noticed that sometimes when you start your computer starts up but when I turn it off I can not restart, strange)
Themler starts with http: // localhost: 12080 / themler_1911410065 / startup / then moves to address http://127.0.0.1:12080/themler_1911410065/joomla/administrator/index.php?option=com_templates&view=style&layout=edit&id=10&editor=1&theme=untitled&login=admin&password=admin&domain=http%3A%2F%2Fthemler. com & ver = 1 & startup = true & desktop = true but does not start the computer (I noticed that sometimes when you start your computer starts up but when I turn it off I can not restart, strange)
dmintermedia
dmintermedia posted this 21 January 2017
when the problem will be solved?
