Booking/Reservation form
skalpo81
skalpo81 posted this 05 January 2017
I'm creating a new website for a Hotel.
I need to create a reservation form in the header.
How can I do it?
I'm creating a new website for a Hotel. I need to create a reservation form in the header. How can I do it?
Support Team posted this 09 January 2017
Since you're using WordPress I suggest that you search for the appropriate WP plugin which creates such form. If this plugin uses Widgets you can add Widget area control to the Header where you will be able to add widget with form in WordPress >> Widgets.
The Widget Area control in available in Themler under the Insert tab.
Hi, Since you're using WordPress I suggest that you search for the appropriate WP plugin which creates such form. If this plugin uses Widgets you can add *Widget area* control to the Header where you will be able to add widget with form in WordPress >> Widgets. The Widget Area control in available in Themler under the Insert tab. Thank you, Olivia
Red Chili
Red Chili posted this 07 November 2018
I can't insert wordpress widget area to reservation form,When i insert widget area it will change to Html(After the sentence WHOEVER YOU ARE, WHATEVER YOU SEEK, IT ALL STARTS HERE)
https://paradise.cmsocean.com/
How can I do it?
I can't insert wordpress widget area to reservation form,When i insert widget area it will change to Html(After the sentence WHOEVER YOU ARE, WHATEVER YOU SEEK, IT ALL STARTS HERE) https://paradise.cmsocean.com/ How can I do it?
admin34
admin34 posted this 08 November 2018
You will not help me. This problem has been going on for over three weeks. It has now been 5 days since I responded to your last solution which didn't work. this is very disappointing your chose to go down this path.
I gave you 24 hours to comment on my problem you have not. You have left me no choose but to tell my story to the world, that your support is very bad.
You will not help me. This problem has been going on for over three weeks. It has now been 5 days since I responded to your last solution which didn't work. this is very disappointing your chose to go down this path. I gave you 24 hours to comment on my problem you have not. You have left me no choose but to tell my story to the world, that your support is very bad.
Red Chili
Red Chili posted this 09 November 2018
Sorry,I did't see your comment,There are lost of themler experts are there with good support team to support.
First we have to search problem under particular heading,,,,if you didn't find anything write as a new question.
I think support team will help you.That is there responsibility....
Sorry,I did't see your comment,There are lost of themler experts are there with good support team to support. First we have to search problem under particular heading,,,,if you didn't find anything write as a new question. I think support team will help you.That is there responsibility....
