Part of the page is hidden under the menu.
aureliop
aureliop posted this 10 January 2017
Hi.
I have a problem, and maybe yo can help me, part of they are under the menu.
Please, take a look at this link:
http://fantazia.mx/wordpress/en/eclectica-figurativa-en/f-balance-en/
If you select the [more information] button at the bottom right, the page moves to show two text fields.
As you can see, part of they are under the menu.
Is it a menu setup matter?
Thanks.
Aurelio
Hi. I have a problem, and maybe yo can help me, part of they are under the menu. Please, take a look at this link: http://fantazia.mx/wordpress/en/eclectica-figurativa-en/f-balance-en/ If you select the [more information] button at the bottom right, the page moves to show two text fields. As you can see, part of they are under the menu. Is it a menu setup matter? Thanks. Aurelio
Support Team posted this 10 January 2017
Looks like you menu has the Sticky Extension applied. Open the Horizontal Menu control settings on the top and remove the Sticky extension.
Hi, Looks like you menu has the Sticky Extension applied. Open the Horizontal Menu control settings on the top and remove the Sticky extension. Sincerely, Hella
aureliop
aureliop posted this 11 January 2017
HI Hella,
Id' like to see the menu every time. If I remove Sticky Extension the the menu disappears when the page is scrolled up.
Would you tell me how can I configure it.
Aurelio
HI Hella, Id' like to see the menu every time. If I remove Sticky Extension the the menu disappears when the page is scrolled up. Would you tell me how can I configure it. Thanks Aurelio
Support Team posted this 11 January 2017
I thought that you do not want to see the menu fixed on the screen. In this case I do not understand what it hovers? Please provide a marked screen shot showing the problem.
Hi, I thought that you do not want to see the menu fixed on the screen. In this case I do not understand what it hovers? Please provide a marked screen shot showing the problem. Sincerely, Hella
aureliop
aureliop posted this 14 January 2017
Hi Hella
I'm uploading two images. "Wrong.jpg" (my actual page) and "Right.jpg" (what i need)
When I press [Go to Top] button (#) ...button href="#" now it seams yah de page goes under the menu.
What I need is that te page goes to top but it does nos go under the red menu.
HOPE it helps
Best regards
Aurelio
Hi Hella I'm uploading two images. "Wrong.jpg" (my actual page) and "Right.jpg" (what i need) When I press [Go to Top] button (#) ...button href="#" now it seams yah de page goes under the menu. What I need is that te page goes to top but it does nos go under the red menu. HOPE it helps Best regards Aurelio
Support Team posted this 16 January 2017
Hello Aurelio,
When the 'More Info' is clicked the page is opened with anchor link
http://fantazia.mx/wordpress/en/eclectica-figurativa-en/f-balance-en/#masinfo
So at the top the start of the Section "masinfo" appears.
If you want to open the page at different location the anchor should be moved. Locate the Section where you want the page to be opened when 'More Info' is clicked. You may even add HTML control where put the DIV with "masinfo"
Hello Aurelio, When the 'More Info' is clicked the page is opened with anchor link http://fantazia.mx/wordpress/en/eclectica-figurativa-en/f-balance-en/#masinfo So at the top the start of the Section "masinfo" appears. If you want to open the page at different location the anchor should be moved. Locate the Section where you want the page to be opened when 'More Info' is clicked. You may even add HTML control where put the DIV with "masinfo" regards, Aileen
