Help Themler ist not working
ClaudiaK
ClaudiaK posted this 18 January 2017
Hi there,
sorry for disturbing.
The case:
I tried to install the themler theme on wordpress. It won´t work. So I extractet the zip and by using fileziall put it via ftp in wp-content/themes now i got this message, (see attached file)
I didn´t change the name, I tried to change the name, every time the same message.
can you help me?
thanks a lot
claudia
Hi there, sorry for disturbing. The case: I tried to install the themler theme on wordpress. It won´t work. So I extractet the zip and by using fileziall put it via ftp in wp-content/themes now i got this message, (see attached file) I didn´t change the name, I tried to change the name, every time the same message. can you help me? thanks a lot claudia
Support Team posted this 18 January 2017
What was the issue installing the theme in the regular way? Is there an error message?
Hi, What was the issue installing the theme in the regular way? Is there an error message? Sincerely, Hella
ClaudiaK
yes every time. it says it cant copy several files. It´s 1&1 hostet. Every Time I got problems there..
A similar error may happen in case there is some confustion in theme name/path. Please make sure you put the theme folder directly into the /path_to_wordpress/wp-content/themes/ folder without any additional subfolders. Also please make sure the theme name on server matches the name given to the theme on export.
Hello, A similar error may happen in case there is some confustion in theme name/path. Please make sure you put the theme folder directly into the `/path_to_wordpress/wp-content/themes/` folder without any additional subfolders. Also please make sure the theme name on server matches the name given to the theme on export. Sincerely, Nettie, BillionDigital Team
ClaudiaK
I got it..
thank you so much..
hugs
claudia
I got it.. thank you so much.. hugs claudia
Claudia, you are welcome!
Claudia, you are welcome! Sincerely, Nettie, BillionDigital Team
