remove logo and white section in sticky and change color menu
skygirl
skygirl posted this 19 January 2017
One of my clients will like to have this menu bar as its old site.
How can I get this. I try with sticky and watching other posts on your forum but to no avail.
On what I have arrived I would also like to remove the white background on the section and leave only the background image which is dark gray.
I also like that the logo in the coueur is not visible when we go down the page.
And finally that the writing of the menu goes blank.
The old site with the right menu : http://hacienda-paysage.fr/
The current site with themler : http://agencecreationsites.fr/
If possible with screenshot please because I think doing the right manipulations but either I'm wrong or it does not work.
thank you so much
Hello, One of my clients will like to have this menu bar as its old site. How can I get this. I try with sticky and watching other posts on your forum but to no avail. On what I have arrived I would also like to remove the white background on the section and leave only the background image which is dark gray. I also like that the logo in the coueur is not visible when we go down the page. And finally that the writing of the menu goes blank. The old site with the right menu : http://hacienda-paysage.fr/ The current site with themler : http://agencecreationsites.fr/ If possible with screenshot please because I think doing the right manipulations but either I'm wrong or it does not work. thank you so much
Support Team posted this 20 January 2017
Unfortunately you cannot control the visibility of controls on scroll.
There is a tutorial that demonstrates how to do it manually via custom css:
http://answers.themler.com/articles/96208/change-header-height-on-scroll
In general, you can make two Image controls and hide them depending on the affix state. For this you should know the specific image control class that can be found using browser dev tool if you know how to use it.
Themler team
Hi, Unfortunately you cannot control the visibility of controls on scroll. There is a tutorial that demonstrates how to do it manually via custom css: http://answers.themler.com/articles/96208/change-header-height-on-scroll In general, you can make two Image controls and hide them depending on the affix state. For this you should know the specific image control class that can be found using browser dev tool if you know how to use it. Thank you, Themler team
