Search form for onepagers in wordpress
mburgener
mburgener posted this 19 January 2017
Is there a way to get the search form working on a one pager?
created a onepager using some existing templates from billionthemes:
https://blweb.ch/ps/
Template is also attached
PS: no hurry
kind regards
Mike
Is there a way to get the search form working on a one pager? created a onepager using some existing templates from billionthemes: https://blweb.ch/ps/ Template is also attached PS: no hurry kind regards Mike
Support Team posted this 19 January 2017
Search is a WP functionality. I suggest that you set some static page as front page (in WordPress reading Settings) and then move all Sections to the content of this page. WP cannot search between theme design elements. It searched between content.
Hi, Search is a WP functionality. I suggest that you set some static page as front page (in WordPress reading Settings) and then move all Sections to the content of this page. WP cannot search between theme design elements. It searched between content. Thank you, Olivia
mburgener
ok, i thought it goes in to that direction!
Thank you very much!
btw you could remove the attachment and set this question public if you like
Kind regards
Mike
ok, i thought it goes in to that direction! Thank you very much! btw you could remove the attachment and set this question public if you like Kind regards Mike
mburgener
mburgener posted this 23 January 2017
got it working using a front page like you suggested.
However got in to another problem, using the wordpress search for onepage sites seems not to do a good job, i think it would make more sense to just use the "browser integrated search" function, so that the browser is jumping to the right section of the page.
Anybody knowing a good solution? is there a way to create a form which makes use of the browser search? i think i alredy seen that in use somewhere.
regards
Mike
got it working using a front page like you suggested. However got in to another problem, using the wordpress search for onepage sites seems not to do a good job, i think it would make more sense to just use the "browser integrated search" function, so that the browser is jumping to the right section of the page. Anybody knowing a good solution? is there a way to create a form which makes use of the browser search? i think i alredy seen that in use somewhere. regards Mike
Support Team posted this 24 January 2017
Unfortunately we do not have ready solution for integrating browser search into webpage.
Themler Team
Hi, Unfortunately we do not have ready solution for integrating browser search into webpage. Thank you, Themler Team
