header background change when scrolling
David Marchione
David Marchione posted this 27 January 2017
How to make header background change when scrolling?
Support Team posted this 27 January 2017
When you add the Sticky extension for the Header there are extension settings in the drop-down, you can edit the background color there. Note, that it will change the header background only. If you have any other controls within the header with the own background color, that won't be changed.
Hi, When you add the Sticky extension for the Header there are extension settings in the drop-down, you can edit the background color there. Note, that it will change the header background only. If you have any other controls within the header with the own background color, that won't be changed. Sincerely, Hella
David Marchione
David Marchione posted this 29 January 2017
Thanks I'll check it out
Support Team posted this 30 January 2017
Let us know if you need our further help.
Let us know if you need our further help. Sincerely, Hella
