themler does not start
1157-619
1157-619 posted this 29 January 2017
There is a white screen and below is displayed:
"Waiting for 127.0.0.1 ...."
Nothing happens ! Only after a restart the software starts. This has been the case for several weeks.
Why is Themler not running?
There is a white screen and below is displayed: "Waiting for 127.0.0.1 ...." Nothing happens ! Only after a restart the software starts. This has been the case for several weeks. Why is Themler not running?
12 Comments
Support Team posted this 29 January 2017
Hello, Please follow the steps below: 1. Backup all theme folders somewhere on your computer if there are any. The path is shown in the Theme Management screen after selecting some CMS, for example, `C:\ProgramData\Themler\hd_data\themler_xxxxxxxxx\wordpress`. 2. Uninstall Themler completely and also check the box for "Remove all CMS content". 3. Check if the following folders are still present: C:\Program Files (x86)\Themler C:\ProgramData\Themler 4. If they exist, remove them. 5. Reboot the machine after uninstalling Themler, so that all Themler services are removed for sure. 6. Temporarily disable antivirus and firewall. 7. Download latest version of Themler for Windows from themler.com, install it and try to start with Themler for any CMS and create a theme. Please let us know the result. Sincerely, Nettie, BillionDigital Team
1157-619
1157-619 posted this 14 February 2017
I've done everything, but the problem is still there.
Firewall and Antivirus is off. I have the latest version installed.
Sometime it starts but if i close the software and open again later,
it always shows a white screen.
Hello, I've done everything, but the problem is still there. Firewall and Antivirus is off. I have the latest version installed. Sometime it starts but if i close the software and open again later, it always shows a white screen.
Support Team posted this 14 February 2017
Could you please provide log file created with Themler Diagnostics Tool according to this instruction:
http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation
Hello, Could you please provide log file created with Themler Diagnostics Tool according to this instruction: http://answers.themler.com/articles/13879/themler-desktop-troubleshooting#installation Thank you, Nettie, BillionDigital Team
1157-619
1157-619 posted this 15 February 2017
Hello, its here >Attachments
Support Team posted this 15 February 2017
Thanks for the log file. It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files.
Please try to add the following folder to your antivirus/firewall white list:
C:\Program Files (x86)\Themler\
and try to install and run Themler once again.
Let us know if this helps.
Hello, Thanks for the log file. It can happen that antivirus or firewall are not disabled completely even if stopping them and are blocking/removing necessary files. Please try to add the following folder to your antivirus/firewall white list: C:\Program Files (x86)\Themler\ C:\ProgramData\Themler and try to install and run Themler once again. Let us know if this helps. Sincerely, Nettie, BillionDigital Team
1157-619
1157-619 posted this 16 February 2017
It has not changed, the problem still exists.
Here new Attachment
Hello, It has not changed, the problem still exists. Here new Attachment
Support Team posted this 17 February 2017
please open the URL directly in browser
http://127.0.0.1:12080/themler_848223627/wordpress
Let us know if it opens or not.
Hello, please open the URL directly in browser http://127.0.0.1:12080/themler_848223627/wordpress Let us know if it opens or not. Regards, Aileen
1157-619
1157-619 posted this 20 February 2017
yes this open with themler empty wordpress theme.
Hello, yes this open with themler empty wordpress theme.
Support Team posted this 20 February 2017
Thanks. Please also try this link:
http://127.0.0.1:12080/themler_848223627/startup
Here you should be able to select and open a theme and work at it as a temporary solution.
Hello, Thanks. Please also try this link: http://127.0.0.1:12080/themler_848223627/startup Here you should be able to select and open a theme and work at it as a temporary solution. Sincerely, Nettie, BillionDigital Team
1157-619
1157-619 posted this 22 February 2017
Hello, i open an html5 theme and work with it and this works !
(i used chrome for this)
Hello, i open an html5 theme and work with it and this works ! (i used chrome for this)
1157-619
if i like to start themler software desktop, themper does not start, but over browser it starts ?!
How can i fix the problem ?
if i like to start themler software desktop, themper does not start, but over browser it starts ?! How can i fix the problem ?
Support Team posted this 27 February 2017
There can be some individual conditions, why Themler does not run directly, in most cases it is caused by some third-party application, or browser add-ons. But as a rule it is really hard to find out what exactly prevent Themler from running directly in such case. We would recommend you to run Themler in a browser as a workaround - it is fully functional when running it in this way.
Hello, There can be some individual conditions, why Themler does not run directly, in most cases it is caused by some third-party application, or browser add-ons. But as a rule it is really hard to find out what exactly prevent Themler from running directly in such case. We would recommend you to run Themler in a browser as a workaround - it is fully functional when running it in this way. Sincerely, Nettie, BillionDigital Team
