4x4 Tours - Page not found (404)
raffe
raffe posted this 31 January 2017
I installed the template "4x4 Tours" from BilionThemes and only displays HOME...
Other pages did not show up, message appears: Page not found (404)
i don't know where is mistake.
link: http://customgarage.com.pl/
Hello, I installed the template "4x4 Tours" from BilionThemes and only displays HOME... Other pages did not show up, message appears: Page not found (404) i don't know where is mistake. link: http://customgarage.com.pl/
Support Team posted this 31 January 2017
Please check the source of menu in Joomla. Looks like the items navigate to non-existing sources.
Hi, Please check the source of menu in Joomla. Looks like the items navigate to non-existing sources. Thank you, Olivia
raffe
Thank You,
Can you tell me where it is?
Hello, Thank You, Can you tell me where it is?
raffe
bad assigns addresses:
http://customgarage.com.pl/index.php/ct-contacts
where it change?
bad assigns addresses: http://customgarage.com.pl/**index.php**/ct-contacts where it change?
Support Team posted this 01 February 2017
Try to switch off the Search engine friendly URLs. You can find it under the System >> Global configuration in Joomla.
Hi, Try to switch off the Search engine friendly URLs. You can find it under the System >> Global configuration in Joomla. Sincerely, Hella
