Prestashop Hook displayTop
Linkebel
Linkebel posted this 02 February 2017
I have to add this hook displayTop
I want to use a menu other than that of Themler and this menu only goes on this hook
How can I do ?
Thank you.
Hello, I have to add this hook displayTop I want to use a menu other than that of Themler and this menu only goes on this hook How can I do ? Thank you.
8 Comments
Linkebel
Linkebel posted this 03 February 2017
Up please !
Up please !
Linkebel
Linkebel posted this 06 February 2017
Up ;-)
Up ;-)
Support Team posted this 07 February 2017
Please try adding Hook To Columns control:
It creates hookTop position.
Hi, Please try adding Hook To Columns control: !hook-top-column.png! It creates hookTop position. Thank you, Olivia
Linkebel
Linkebel posted this 07 February 2017
I have already tried this solution and it does not work.
I would need hook displayTop and not Top Column
Is it possible ?
Thank you for your help.
Hello, I have already tried this solution and it does not work. I would need hook displayTop and not Top Column Is it possible ? Thank you for your help.
This control uses displayTop hook:
Does this module appear in this hook with the default PrestaShop theme?
Hi, This control uses displayTop hook: !ps-top-hook.png! Does this module appear in this hook with the default PrestaShop theme? Thank you, Olivia
stryjek-www
stryjek-www posted this 11 February 2018
witam dlaczego ja w swoim themler mam tylko to co na zdjeciu
enter image description here
Jak zmienić pozycję wyszukiwarki . Chcę dać wyszukiwarkę obok wyboru ceny i koszyka na górze
witam dlaczego ja w swoim themler mam tylko to co na zdjeciu ![enter image description here][1] Jak zmienić pozycję wyszukiwarki . Chcę dać wyszukiwarkę obok wyboru ceny i koszyka na górze [1]: http://stryjek-www.pl/images/ewew.jpg
stryjek-www
Od lat kożystam z joomla. W joomla mam opcje pokazania pozycji menu . Tak jak w załączniku. Gdzie w Prestashop znajdę pozycje Hook ?
Od lat kożystam z joomla. W joomla mam opcje pokazania pozycji menu . Tak jak w załączniku. Gdzie w Prestashop znajdę pozycje Hook ?![enter image description here][1] [1]: http://stryjek-www.pl/images/dddd.jpg
Support Team posted this 13 February 2018
Is PrestaShop 1.6 or 1.7 themes?
Unfortunately PS does not provide page topology feature you're referring to.
Please note that Themler provides own Search control for PS themes (Insert tab >> More) which you can insert in any place on the template.
Hello, Is PrestaShop 1.6 or 1.7 themes? Unfortunately PS does not provide page topology feature you're referring to. Please note that Themler provides own Search control for PS themes (Insert tab >> More) which you can insert in any place on the template. Thank you, Olivia
