Submenu only show on click on.
arawolf
arawolf posted this 03 February 2017
I want a submenu only visible when i click on the mainmenu -item. how can i fix this for a joomla site.
8 Comments
Support Team posted this 03 February 2017
You mean the horizontal menu should drop down the submenus only when you click on it? There is no such option.
Hi, You mean the horizontal menu should drop down the submenus only when you click on it? There is no such option. Sincerely, Hella
arawolf
yes, that's a pitty,
lascrea
lascrea posted this 04 February 2017
In Joomla administration:
Got to: Menu Manager / Menu Items / Edit Menu Item / Menu Item type / Select : System Links then External URL / In the space provide to Link put symbol # like link for the menu item of the mainmenu.
After you can create your sub-menu under de menu item.
Try.
Lascrea.
> I want a submenu only visible when i click on the mainmenu -item. how can i fix this for a joomla site. In Joomla administration: Got to: Menu Manager / Menu Items / Edit Menu Item / Menu Item type / Select : System Links then External URL / In the space provide to Link put symbol # like link for the menu item of the mainmenu. After you can create your sub-menu under de menu item. Try. Lascrea.
lascrea
lascrea posted this 06 February 2017
Have you tried my method.
> yes, that's a pitty, Hello, Have you tried my method.
arawolf
arawolf posted this 06 February 2017
Sorry but i don't understand no i have one menu with 3 items. And under each item there is a submenu. But these submenu must showed on a different location. may be you can look. test-ararin.be/test3 NOw the submenu's are both showed as you can see.
Support Team posted this 08 February 2017
Hello Kris,
now the menu at http://test-ararin.be/test3/ doesn't have submenus at all. Please describe what you'd like to get in more details. The issue is not clear.
Hello Kris, now the menu at http://test-ararin.be/test3/ doesn't have submenus at all. Please describe what you'd like to get in more details. The issue is not clear. regards, Aileen
arawolf
arawolf posted this 09 February 2017
Aileen, the menu have submenu's but there are show on a other location. Yesterday evening the problem is solved. Thnx
Support Team posted this 13 February 2017
Great!
Please let us know if you need our further assistance here.
Themler Team
Hi, > Yesterday evening the problem is solved. Great! Please let us know if you need our further assistance here. Thank you, Themler Team
