Joomla Home Page Template
tersia
tersia posted this 14 February 2017
I cant seem to access Home Template for Joomla. It keeps going back to Page not Found 404 Template. Is there something I have to enable first?
Support Team posted this 14 February 2017
Please refer to the article:
http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes
If that does not help, try to also switch off the plug-ins . If that also does not help, provide an access to the site back end so we could review the settings.
Hi, Please refer to the article: http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes If that does not help, try to also switch off the plug-ins . If that also does not help, provide an access to the site back end so we could review the settings. Sincerely, Hella
remmertkool
remmertkool posted this 06 October 2017
Hello Tersia/ Hella, I have installed Themler locally for making Joomla Templates.
Also I can't succeed opening a "Home"Template. When i click on Home it autoimatically gets to the 404 page.
What can i do because the link above did not help me. It even looks like a different version I have got...
In addition to this problem I have got the following arror message: Server Permissions-Insufficient pertmissions (see attachment)
Best regards,
Remmert
Hello Tersia/ Hella, I have installed Themler locally for making Joomla Templates. Also I can't succeed opening a "Home"Template. When i click on Home it autoimatically gets to the 404 page. What can i do because the link above did not help me. It even looks like a different version I have got... In addition to this problem I have got the following arror message: Server Permissions-Insufficient pertmissions (see attachment) Best regards, Remmert
Support Team posted this 07 October 2017
Please check the permissions as explained in the following link:
https://answers.themler.io/articles/65488/troubleshooting-read-first
As for the Home template, you need to open the Joomla admin panel and check that you have the proper menu assigned into the menu position. The proper menu is the one that includes the default Joomla menu item.
Hi, Please check the permissions as explained in the following link: https://answers.themler.io/articles/65488/troubleshooting-read-first As for the Home template, you need to open the Joomla admin panel and check that you have the proper menu assigned into the menu position. The proper menu is the one that includes the default Joomla menu item. Sincerely, Hella
daniel56
daniel56 posted this 23 November 2018
I have the same problem.
By the way. I preferred Artisteer so much because I never had problems like this and it was possible edit articles without themler.
I have the same problem. By the way. I preferred Artisteer so much because I never had problems like this and it was possible edit articles without themler.
